Prove Triangle Inequality: ||a|| - ||b|| ≤ ||a - b||
The discussion revolves around proving the triangle inequality in the context of vector norms, specifically the inequality ||a|| - ||b|| ≤ ||a - b||. Participants are exploring various interpretations and approaches to this problem.
  • Some participants are considering the relationship between the given inequality and the standard triangle inequality, questioning whether the original poster's expression can be derived from it. Others suggest starting from known inequalities and manipulating them to fit the problem.
The discussion is ongoing, with participants offering hints and alternative perspectives. There is no explicit consensus on the approach to take, but several lines of reasoning are being explored, indicating a productive exchange of ideas.
Participants are grappling with the definitions and implications of the triangle inequality, as well as the conditions under which the original expression holds true. There is some confusion regarding the correct formulation of the triangle inequality being referenced.
cscott
"Use the triangle inequality to prove that:
[tex]||\vec{a}|| - ||\vec{b}|| \le ||\vec{a} - \vec{b}||[/tex]"
I can start from that expression and prove it true using the Cauchy-Shwarz inequality but I don't think that's what's asked. Any hints?
Do they mean the following triangle inequality:
[tex]||\vec{a}|| + ||\vec{b}|| \le ||\vec{a} + \vec{b}||[/tex]
because it can be proved from that by picking a and b correctly.
Yeah but it should be ||a|| + ||b|| >= ||a + b||
Start with
[tex]||\vec{u} + \vec{v}|| - ||\vec{v}|| \le ||\vec{u}||[/tex]
and choose
[tex]\vec{u} + \vec{v} = \vec{a}[/tex]
The rest should be pretty self evident after that.
Right, sorry. So you got the answer?
river_rat said:
Start with
and choose
I got it but how do I justify saying that?
