Worldlines - no need for ref frames?
  • Context: Graduate
  • Thread starter Thread starter pivoxa15
    Frames
The discussion revolves around the concept of worldlines in the context of special relativity, particularly whether they can be used to relate events without the necessity of reference frames. Participants explore the implications of this idea as presented in Wheeler and Taylor's "Intro to SR" and examine the relationship between worldlines, spacetime diagrams, and reference frames.
  • One participant questions the assertion that worldlines allow for scientific analysis without reference frames, arguing that a reference frame is necessary for defining worldlines in spacetime diagrams.
  • Another participant suggests that the physics of worldlines and their geometric relations are independent of the choice of reference frame, drawing an analogy to Euclidean geometry.
  • Some participants propose that while calculations of quantities like proper time may yield consistent results across different frames, the validity of these results may depend on the use of inertial reference frames and the conditions of Minkowskian spacetime.
  • There is a reiteration of the idea that without a reference frame, the concept of a worldline becomes meaningless, as it relies on the existence of an observer to define events in spacetime.
Participants express differing views on the necessity of reference frames for worldlines. While some argue that reference frames are essential, others contend that the geometric properties of worldlines can be understood independently of them. The discussion remains unresolved with multiple competing perspectives.
Participants note that the discussion may be limited by assumptions regarding the nature of spacetime, the role of inertial frames, and the implications of acceleration effects on worldlines.
pivoxa15
"In Principle, worldlines allow us to relate events on one another - to do sciecne without using reference frames at all".
This was in Wheeler and Taylor's Intro to SR book.
My question is, isn't this false? Because worldlines exist in a spacetime diagram. Vertical being time and horizontal is space. One reference frame is always needed, which normally is the one that does not move wrt space. Hence it registers the greatest proper time. All other worldlines are created wrt to this stationary reference frame (i.e. the speed and directions of the particles that translate to worldlines are calculated or measured wrt to the stationary frame). So one reference frame must be needed hence contradicting the statement?
I think what they are trying to say is that
the physics involved relies only on the worldlines and their [Minkowski-]geometric relations to events and other figures... and not on the choice of axes (choice of reference frame) used to draw the picture. By direct analogy, the properties of Euclidean geometry rely on the figures themselves and not on the choice of axes used to draw the picture.
So they are trying to say that no matter which frame you are in, you will calculate the same major results such as the proper time for different moving objects moving wrt you. All reference frames are arbitary and there are quantities that are independent of all ref frames.
Correct?
Correct?
Interval ds is independent of ref. frame:
ds^2 = (ct)^2 - (dx^2 + dy^2 +dz^2).
If only one spatial dimension x is involved: ds^2 = (ct)^2 - dx^2.
But I think this is only valid with inertial ref. frames (or when you can ignore acceleration effects), that is in a Minkowskian space-time, that is, in a "flat" space-time. A lot of people here can correct me.
pivoxa15 said:
"In Principle, worldlines allow us to relate events on one another - to do science without using reference frames at all".
Well, I'm not sure what the meaning was supposed to be wrt everything after the dash there? Doesn't sound right "as worded" here.
Without a worldline, a Minkowski worldline diagram is pretty much useless. It's like defining the location of something with no point of reference anywhere anytime. Space & time w/o any observer.
  • · Replies 36 ·
  • · Replies 38 ·
  • · Replies 30 ·
  • · Replies 125 ·
9K
  • · Replies 57 ·
