Register to reply
Weightless speed
by sweetshelly
Tags: speed, weightless
Share this thread:
sweetshelly
#1
Sep23-06, 05:41 PM
P: 9
Question 1:
At what speed must you go over a speed bump if people in your car are to feel weightless?
car speed V=12m/s
bump radius 35m
I don't know how to approch this problem. please help?
Question2:
A 0.075kg toy airplane if tied to the ceiling with a string. When the airplane's motor is started, it moves with a constant speed of 1.21m/s in a horizontal circle of radius 0.44m
a) Find the angle the string make with the vertical
b) the tension in the string
I found the answer to a. What I did was use the formula
Thea=tan-1(Vsquare/gr)
V=1.21m/s
g=9.81m/s square
r=0.44m
So the answer is 18.7 degree
How do I slove for the tension of the string?
Question 3:
A monkey swings a ball tied to a string in a circle over her head at constant speed. The ball:
a. has total force acting on it that is zero.
b. has a total force acting on it that it is not zero.
c. has an acceleration that is zero. (not C because constantly have accer because constanly changing direction)
d. has a constant velocity.
Question 4:
A box is pushed along a horizontal surface with a horizontal force that is equal in magnitude to the force of kinetic friction between the box and surface. In this case:
a. the box's speed will decrease at a constant rate.
b. the box's speed will increase at a constant rate.
c. the book will not be able to move, because the coefficent of static friction must exceed the coefficient of kinetic friction.
d. the box will move at constant speed.
Phys.Org News Partner Science news on Phys.org
Experts defend operational earthquake forecasting, counter critiques
EU urged to convert TV frequencies to mobile broadband
Sierra Nevada freshwater runoff could drop 26 percent by 2100
Astronuc
#2
Sep23-06, 05:48 PM
Admin
Astronuc's Avatar
P: 21,880
At what sppeed must you go over the bump if people in your car are to feel weightless?
car speed V=12m/s
bump radius 35m
Kind of a strange question since it asks for speed and then it gives 12 m/s.
Think of centripetal acceleration, v2/r, which must equal the acceleration of gravity.
sweetshelly
#3
Sep23-06, 06:00 PM
P: 9
Quote Quote by Astronuc
acp=v2/r
solve (12square)/(35)= 4.11
This is not the answer because in the back of the book it say that the answer is 19m/s.
What other way can I solve this problem?
Astronuc
#4
Sep23-06, 06:14 PM
Admin
Astronuc's Avatar
P: 21,880
Weightless speed
To be weightless on arc of R, the centripetal acceleration must = g = 9.8 m/s2,
so g = v2/R => gR = v2 => v = sqrt (gR). Perhaps the textbook rounds up.
sweetshelly
#5
Sep23-06, 06:32 PM
P: 9
v = sqrt (gR) = .52915
nope still not the answer we are looking for. Which in this case is 19m/s (textbook answer)
What else can we do?
Astronuc
#6
Sep23-06, 07:35 PM
Admin
Astronuc's Avatar
P: 21,880
Quote Quote by sweetshelly
What numbers did you use?
g = 9.8 m/s2 and R = 35 m.
Astronuc
#7
Sep23-06, 07:41 PM
Admin
Astronuc's Avatar
P: 21,880
How are you doing on the other problems?
The 0.075kg plane produces a centripetal force in the circular plane (horizontal). Think of the formula for centripetal force.
Now the string is at some angle with respect to the plane. The tension in the string acts along the string, and it is pulling on the plane. One must find the component of centripetal force which is parallel with the string.
Register to reply
Related Discussions
Weightless physics question General Physics 3
Does the speed of a wave in a spring depend on the maximum speed of each coil? Introductory Physics Homework 3
Weightless light? Quantum Physics 1
Difference between average speed, instantaneous speed, velocity, acceleration? help! Introductory Physics Homework 5
Moon-landing conspiracy theories weightless but persistent General Physics 12
