Thread Closed
Average Speed vs. Average velocity
Share Thread Thread Tools
Sep24-06, 02:10 PM   #1
Do you think that average speed and average velocities are usually the same for something in motion?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Sep24-06, 02:16 PM   #2
Recognitions:
Homework Helper Homework Help
Generally, they are synonyms, but velocity is usually used in the context of physics, I guess.
Sep24-06, 02:21 PM   #3
Quote by radou
Ya I mean in Physics.
Are they the same? what are the differences?
Sep24-06, 02:24 PM   #4
Recognitions:
I guess there's no difference, except that you usually don't use the term 'speed' in physics.
Sep24-06, 02:32 PM   #5
Quote by radou
Thanks
I have one more question, to find the instantaneous speed between lets say 0 and 3 seconds using a distance vs. time graph. I first draw the line fo best fit then I would find the slope right?
Sep24-06, 02:36 PM   #6
Quote by caprija
It is like comparing apples and pears, they are completely different. One is a scalar the other is a vector quantity.
Sep24-06, 02:38 PM   #7
Actually, the average speed is the [tex]\frac{total distance travelled}{total time taken}[/tex], while average velocity is [tex]\frac{total displacement}{total time taken}[/tex]. Remember, the displacement can be zero when the distance is not.
Sep24-06, 02:42 PM   #8
Quote by MeJennifer
ok so i'm confused now, when we're talking about something in MOTION is the average speed and the average velocity usually the same?
Sep24-06, 02:46 PM   #9
Recognitions:
Quote by neutrino
Hm, could you clarify what you meant by that?
Sep24-06, 02:49 PM   #10
Quote by radou
It is possible to have an average velocity of zero, for example.
(You travel at 5 m/s for 2 sec and then you travel at -5 m/s (backwards) for 2 sec)
...and not so with speed (it is a scalar quantity).
Sep24-06, 02:52 PM   #11
Recognitions:
Quote by Omega_6
I know, but I still don't understand the statement above. Nevermind.
Sep24-06, 03:07 PM   #12
I wrote:
"I do think that average speed and average velocity are usually the same for something in motion because it's still measuring time. The only diffference is that when calculating the velocity, you're calculating the rate at which the object changes it's postition."
does that sound about right?
Sep24-06, 03:13 PM   #13
Quote by radou
Went offline for some time...What exactly did you not understand?
Sep24-06, 03:15 PM   #14
Speed is a scalar quantity. If we designate forwards as positive movement and backwards as negative movement. I can run back and forth at 1m/s and arive where I started and my speed would still be 1m/s.
Now if we are using velocity, it is a VECTOR quantity. This means that you need to indicate MAGNITUDE and DIRECTION.
If you were to run 30,000 miles forward and then 30,000 miles backwards in 3 hours, your speed would be [tex]v=\frac{60000miles}{3hours}=\frac{20000miles}{hour} [/tex]
BUT if you were to give velocity... [tex]\vec{v}=\frac{(30000miles)+(-30000miles)}{3hours}=\frac{0miles}{3hours}=\frac{0miles}{hr} [/tex]
Get it?
Notice the arrow above v to designate whether it is a scalar quantity of a vector quantity.. [tex] \vec{v}=velocity [/tex] [tex] v=speed [/tex]
Sep24-06, 03:20 PM   #15
Recognitions:
Quote by Checkfate
...BUT if you were to give velocity... [tex]\vec{v}=\frac{(30000miles+(-30000miles)}{3hours}=\frac{0miles}{3hours}=\frac{0miles}{hr} [/tex]
Get it?
If you are so 'aware' of the difference between vector and scalar quantities, then you should be more careful when writing equalities.
Sep24-06, 03:20 PM   #16
Quote by Checkfate
Get it?
Yes, Thanks I get it.
But the question is really confusing, are they usually same or not?
Sep24-06, 03:25 PM   #17
If you're moving with a constant velocity (speed is constant, direction is constant), then the magnitude of average velocity = average speed. In such a case, the dist-time graph will always be a straight line.
Thread Closed
Thread Tools
Similar Threads for: Average Speed vs. Average velocity
Thread Forum Replies
Constant velocity questions (average speed vs. average velocity) Introductory Physics Homework 2
Average speed & average velocity Problem Introductory Physics Homework 11
Average speed and average velocity?? Introductory Physics Homework 1
Average Speed/Average Velocity Problem Introductory Physics Homework 4
