Calculating Electric Field of a Polarized Sphere
The discussion revolves around calculating the electric field of a polarized sphere, specifically focusing on the polarization defined as \textbf{P}=k\textbf{r}. Participants are examining the implications of bound surface charge density (\sigma_b) and bound volume charge density (\rho_b) in relation to the electric field both inside and outside the sphere.
  • Participants discuss various methods for calculating \sigma_b and \rho_b, with some suggesting the use of Gauss's law while others question its applicability due to the lack of spherical symmetry in \sigma_b. There is also exploration of potential integrals and their relation to the electric field.
The discussion is active, with participants sharing different interpretations of the problem and the results of their calculations. Some have offered guidance on using Gauss's law, while others are questioning the assumptions made regarding the symmetry of the problem and the application of potential integrals.
There are indications of confusion regarding the correct expressions for \sigma_b and \rho_b, with participants debating the impact of the dot product in the context of the polarization vector. Additionally, there are references to specific steps in Griffiths' text that may require further review.
abode_x
From Griffiths, Problem 4.1
A sphere of radius R carries a polarization
[tex] \textbf{P}=k\textbf{r}[/tex]
where k is constant and r is the vector from the center.
a. Calculate [tex]\sigma_b[/tex] and [tex]\rho_b[/tex].
b. Find the field inside and outside the sphere.
part a is handled simply by [tex]\sigma_b=\textbf{P}\cdot\hat{n}[/tex] and [tex]\rho_b=-\nabla\cdot\textbf{P}[/tex].
part b is handled most easily by using the bound charges found and gauss's law, giving: [tex]\textbf{E}=\frac{-kr}{\epsilon_0}\hat{r}[/tex] and 0 outside.
part b can also be handled by first getting the potential through:[tex]\frac{1}{4\pi \epsilon_0}\int_v \frac{\hat{r}\cdot\textbf{P}}{r^2}d\tau[/tex]. Then just get the negative gradient of V to yield E. This gives the same result as method 1 for both inside and outside (P=0 when dealing with outside case).
Now, i tried to get the field, again by computing for V but this time with:
[tex]V(r)=\frac{1}{4\pi \epsilon_0}\oint_s\frac{\sigma_b}{r}da + \frac{1}{4\pi \epsilon_0}\int_v\frac{\rho_b}{r}d\tau[/tex]. The answer i get using this integral is different. i would like to know if in the first place this integral is applicable? if I'm trying to get the potential inside, do i still consider the surface bound charge?
the best i managed was an answer negative to the correct one. (but this had 1 dubioius step involved). also, i could only attempt to get the potential inside. can anyone make the last method work (for both outside and inside)? or share why it doesnt?
thanks.
\sigma_b is not spherically symmetric, so E iinside is not.
You can't use Gauss as you do in that case.
Your integrals should give the right answer if you mean r-r'
when you write r.
Gauss's law actually gives the right answers. [tex]\sigma_b=kR[/tex] everywhere on the surface if you apply the definition. likewise, [tex]\rho_b=-3k[/tex]. these are symmetric and so is E inside and out.
as for the r-r' hint. i don't see it yet, but i will try it. thanks.
i was wrong though, about my claim that i got E=0 outside using the second method. that's another issue - how to get that result.
\sigma_b does not equal kR. It equals kR cos\theta because of the dot product. Go back and study Griffriths some more, then come back to the problem.
Meir Achuz, I don't quite understand this.
If [itex]P(r)=kr \vec{e_r}[/itex]
Then, won't [tex]\sigma_b[/tex] be
[tex]\sigma_b = \vec{P}.\hat{n} = k R (\vec{e_r}.\vec{e_r}) = kR[/tex]
Whoops. I apologize. I had read it as P=a fixed vector.
Using Gauss as in the first post gives the right answer.
To use the potential integrals still requires r-r'.
Thanks for catching my carelessness.
  • · Replies 20 ·
