Proving No Intersection: y=2x-1 & y=x^4+3x^2+2x
  • Thread starter Thread starter msimard8
    Intersection
The discussion revolves around proving that the line described by the equation y=2x-1 does not intersect the curve defined by y=x^4 + 3x^2 + 2x. Participants are exploring indirect proof techniques to establish this claim.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss setting the equations equal to each other and consider substitutions to simplify the problem. There is mention of deriving a contradiction based on the properties of the resulting polynomial.
Some participants are actively engaging with the problem, suggesting substitutions and discussing the implications of their findings. There is recognition of errors in reasoning and calculations, indicating a productive exploration of the topic.
Participants are working under the constraints of using indirect proof and are addressing potential errors in their calculations and assumptions about the roots of the equations.
msimard8
Heres the quesion
Prove that the line whose equation is y=2x-1 does not intersect the curve with equation y=x^4 + 3x^2 +2x.
We are suppose to solve this using indirect proof, thus assuming the equations do intersect, and proving that wrong.
i let the y's equal each other, but that isn't getting me anywhere
where should i start.
thanks
msimard8 said:
Heres the quesion
thanks
Of course that is getting you somewhere. Ever thought of substituting x^2 = t ?
Let [itex]y_1(x) = 2x-1[/itex] and [itex]y_2(x) = x^4 + 3x^2 + 2x[/itex]. Look at [itex]f(x) = y_2(x) - y_1(x) = x^4 + 3x^2 + 1[/itex].
If [itex]y_1[/itex] and [itex]y_2[/itex] intersect at [itex]x_0 \in \mathbb{R}[/itex] then [itex]f(x_0) = 0[/itex]. Can you get the contradiction (what do you know about [itex]x^2, \, x^4[/itex] when [itex]x \in \mathbb{R}[/itex]?)?
umm yea i got the roots, x=1 or x=1 or x=-1
but what does that mean
How did you get these roots? Let's start again. Intersection means setting x^4+3x^2+2x = 2x - 1, which implies x^4+3x^2+1=0. Now, as said, substitute x^2 = t, and solve the quadratic equation. Both solutions of this equation t1 and t2 are negative. So, substituting back to x^2 = t means that there is no real solution for the equation x^4+3x^2+1=0, i.e. y1 = x^4+3x^2+2x and y2 = 2x - 1 don't intersect.
thank you so much
i just made a simple sign error in factoring t^2 + t +1
which gave me wrong roots
thanks again
  • · Replies 105 ·
13K
