How to Determine the Ratio of HX to X- in Solution B?
The discussion centers on calculating the ratio of weak acid HX to its conjugate base X^- in Solution B after neutralization with sodium hydroxide. Initially, Solution A contains n moles of HX, and the addition of sodium hydroxide neutralizes one third of HX, resulting in Solution B containing two thirds of HX. Therefore, Solution B contains (2/3)n moles of HX and (1/3)n moles of X^-, leading to a ratio of HX to X^- of 2:1.
  • Understanding of weak acid-base reactions
  • Knowledge of stoichiometry in chemical reactions
  • Familiarity with the concept of moles in chemistry
  • Basic principles of acid dissociation and conjugate pairs
  • Study the principles of weak acids and their dissociation constants
  • Learn about stoichiometric calculations in acid-base neutralization
  • Explore the Henderson-Hasselbalch equation for buffer solutions
  • Investigate the role of sodium hydroxide in neutralization reactions
Chemistry students, educators, and anyone involved in acid-base chemistry or solution preparation will benefit from this discussion.
busted
I am a little stuck on this question :
Solution A contains n moles of a weak acid HX. The addition of some sodium hydroxide to A neutralises one third of the HX present to produce Solution B.
In terms of the amount, n how many moles of HX are present in Solution B?
I think there are one third n moles.
It then asks to determine the ratio : ____(HX)_____
(X^-)
in solution B ... I AM TOTALLY STUCK WHAT TO DO HERE!
ANY HELP PLEASE
Show how you got what you think is correct, then people will be able to help you understand more.
