What Happens to the Sand Bag When Andrew Climbs the Rope?
The discussion revolves around a physics problem involving an athlete climbing a rope while a bag of sand, equal in weight to the athlete, is introduced into the scenario. The participants explore the implications of this setup on the movement of the sandbag as the athlete climbs, particularly focusing on concepts of static equilibrium and forces at play.
  • Participants question the movement of the sandbag in relation to the athlete's climbing behavior, considering whether it would move up or down based on the athlete's speed. There is also discussion about the initial static equilibrium and the implications of the bag's weight being equal to the athlete's.
The conversation is ongoing, with participants examining different interpretations of the problem. Some have raised questions about the setup, including the attachment of the sandbag and the presence of a pulley, while others have pointed out ambiguities in the problem statement. A clarification regarding a frictionless pulley has been introduced, which may influence the understanding of the scenario.
There is uncertainty regarding the exact placement of the sandbag and whether it is attached to the climber or the rope. The lack of clarity in the problem statement has led to varied interpretations among participants.
svtec
Newton's laws?
there is an athlete climbing a rope in gym class. he gets to a point halfway up the rope and is stationary. someone puts a bag of sand that is equal in weight to the athlete. they are both static and then the athlete starts to climb the rope, slowing and speeding up at random intervals.
what happens to the bag of sand as he climbs?
i was thinking that the bag of sand would move up a little bit as he was climbing slower and then down as he is climbing faster?
am i right, or would the bag of sand stay at rest because they are the same weight?
i'm thinking the first one...
tia...
-andrew
Why do you think the bag will move up and down? (except for the shaking of the rope as he climbs) And what does the weight of the sand have to do with it?
i think the problem is trying to imply that the bag is equal in weight to the athlete, implying that they are in static equilibrium initially. the problem states it explicitly and that is why i referred to it. thanks...
-andrew
i think as the climber reached the apex of the climb the bag would approach the floor.
-andrew
I'd be curious to see the exact statement of the problem. The bag doesn't have to be equal in weight to the athlete for there to be static equilibrium. Think about it: the athlete hangs from the rope; he's in static equilibrium because the forces on him (the rope pulling up on him & his weight pulling down on him) balance. No bag of sand needed.
We must be thinking of totally different situations. How is the bag attached to the rope? How is the rope attached to the ceiling? Is there a pulley involved?
I see no reason for the end of the rope to move---sandbag or not---as the man climbs up or down. (Ignoring the stretching of the rope.)
i know. it seems that this problem has a case of ambiguity. i have given you the problem in its entirety leaving out some superfluous information, such as him, what, etc.
i just wanted to see if anyone else could make sense of it.
i would think that there would have to be a pulley involved, but it does not state it.
-andrew
"someone puts a bag of sand that is equal in weight to the athlete"
WHERE was the bag of sand put?? Was that part of the "superflous information" you left out?
Was it attached to the climber?
Was it tied on at the end of the rope?
Was it tied to the other end of the rope after running it to a pulley? (Since the top of the rope was clearly attached to something when he began to climb, I would find that hard to accept.)
Was it set on the floor next to the rope?
edit:
today she said in class that she left out the part about the frictionless pulley.
this makes the problem a little more reasonable.
Ah... just as Halls and I suspected. So, why not take another crack at describing the exact problem and what you think the answer is. And---most importantly---why you think what you think. :smile:
  • · Replies 21 ·
  • · Replies 19 ·
