Nyquist Sampling Thm - Question 2
  • Thread starter Thread starter cepheid
    Sampling
The Nyquist sampling frequency for the differentiated signal dx/dt is identical to that of the original signal x(t), which is denoted as ω_s. The reasoning presented confirms that the spectrum of the differentiated signal remains band-limited to the same maximum frequency ω_M, leading to the conclusion that the Nyquist sampling frequency for dx/dt is also 2ω_M. Thus, the Nyquist sampling frequency does not change when differentiating the signal.
  • Understanding of the Nyquist Sampling Theorem
  • Familiarity with signal differentiation in the frequency domain
  • Knowledge of band-limited signals
  • Basic concepts of Fourier Transform
  • Study the implications of the Nyquist Sampling Theorem in signal processing
  • Explore the properties of band-limited signals and their spectra
  • Learn about the Fourier Transform and its applications in signal analysis
  • Investigate the effects of differentiation on various types of signals
Students and professionals in electrical engineering, signal processing, and anyone involved in analyzing or designing systems that utilize the Nyquist Sampling Theorem.
cepheid
Staff Emeritus
Hello,
This is the same type of question as the one I just posted before. This time I have obtained an answer and would really appreciate it if someone would check my reasoning:
Suppose a signal x(t) has a Nyquist sampling frequency [itex]\omega_s[/itex]. Compute the Nyquist sampling frequency for the following signal in terms of [itex]\omega_s[/itex]:
dx/dt
Again, my first thought was, how does the spectrum of the new signal compare to that of the original? Simple:
[tex]\mathcal{F}\{\frac{dx}{dt}\} = j\omega X(j\omega)[/tex]
So, I obtained an answer through reasoning rather than computation. Here was my reasoning: if the spectrum of the original signal x(t) has some maximum frequency [itex]\omega_M[/itex] i.e. it is band limited such that:
|X(jw)| = 0 for |w| > w_M
then we know that:
[tex]\omega_s = 2\omega_M[/tex]
Furthermore, |jwX(jw)| is zero whenever |X(jw)| is zero, therefore, the spectrum jwX(jw) of the differentiated signal is STILL zero outside of this frequency range i.e. it is band-limited in exactly the same way. Therefore, it's maximum frequency is also [itex]\omega_M[/itex], which means that its Nyquist sampling frequency is also given by [itex]2\omega_M[/itex]. In other words, the Nyquist sampling frequency of the new signal is just the SAME as that of the old signal: [itex]\omega_s[/itex].
Does this reasoning hold?
Yes, it holds alright.
  • · Replies 0 ·
