Centrifugal/Centripetal Acceleration
  • Thread starter Thread starter thebigeis
    Acceleration
The discussion focuses on calculating the centripetal acceleration of a test tube in a lab centrifuge rotating at 4000 RPM. The user initially used a radius of 5 cm instead of the correct 10 cm, leading to an incorrect acceleration calculation of 8772.98 m/s². The correct approach involves using the formula for centripetal acceleration, a = (v²)/r, with the proper radius to achieve accurate results. The user was advised to recalculate using the correct radius of 10 cm.
  • Understanding of centripetal acceleration and its formula a = (v²)/r
  • Basic knowledge of rotational motion and RPM (revolutions per minute)
  • Ability to convert units, specifically from RPM to meters per second
  • Familiarity with the concept of radius in circular motion
  • Learn how to convert RPM to linear velocity in meters per second
  • Study the implications of radius on centripetal acceleration
  • Explore practical applications of centripetal acceleration in laboratory settings
  • Investigate the effects of varying RPM on acceleration in centrifuges
Students in physics, laboratory technicians, and anyone involved in experiments using centrifuges will benefit from this discussion.
thebigeis
This question is actually posted up, but not under a very descriptive title so I'm reposting it and hoping the admin will just close my other one... sorry. Anyway, here is my problem-
#1) A typical lab centrifuge rotates at 4000rpm. Test tubes have to be placed into a centrifuge very carefully because of the very large accelerations. What is the acceleration at the end of a test tube that is 10cm from the axis of rotation in?
What I've already done is find the circumference of the circle, multiplied that by how many revs in a minute the lab does, divide that by 60 to get it in how many revs it does per second, then plug it into the centripetal acceleration equation a=(v^2)/r.
Work:
Known- 4000rpm, r=5cm
Find-a
4000rpm * (2pi(r=5)) = 1256.6m/min
1256.6/60 = 20.94m/s
a = ((v=20.94)^2)/(r=.05m) = 8772.98m/s^2
Obviously, this isn't right; so what do I need to do?
thebigeis said:
Work:
Find-a
Why are you using 5 cm as the radius? Should it not be 10 cm?
AM
  • · Replies 28 ·
