The discussion revolves around methods for measuring high temperatures, specifically up to 1200 degrees Fahrenheit, in the context of using a kiln for glass annealing. Participants explore various temperature measurement options, including thermocouples and pyrometers, while considering the practical applications and requirements for accurate temperature control.
- Technical explanation
- Exploratory
- Debate/contested
- Jeremy inquires about measuring temperatures up to 1200 degrees F and considers using a pyrometer or a thermocouple with a multimeter.
- One participant suggests that a thermocouple is likely the easiest option and asks about the specific application.
- Jeremy explains the context of his need, mentioning he built a kiln for glass annealing and requires accurate temperature measurement for firing schedules.
- Another participant confirms that kiln applications typically use thermocouples and provides information about temperature control modules that can read thermocouples directly and offer control features.
- Additional advice is given regarding compatibility of controllers with thermocouple types and the importance of considering contact ratings for inductive loads in the kiln setup.
- Jeremy shares that he found an old analog pyrometer with a type K thermocouple for a low price and expresses hope that it will suffice for his needs.
Participants generally agree on the utility of thermocouples for high-temperature applications, particularly in kiln settings. However, there are varying opinions on the necessity and timing of purchasing additional equipment like temperature controllers, with some participants providing cautionary advice about compatibility and load ratings.
There are unresolved considerations regarding the specific requirements for temperature measurement accuracy and the potential limitations of using an old analog pyrometer. The discussion also touches on the need for careful selection of components based on the specific kiln setup and operational parameters.
This discussion may be useful for individuals involved in glassworking, kiln operation, or those interested in high-temperature measurement techniques in experimental or industrial settings.
