Gun shot at angle
by Fanjoni
Tags: angle, shot
Fanjoni
Fanjoni is offline
#1
Oct8-06, 12:40 AM
P: 11
A pistol that fires a signal flare gives the flare an initial speed (muzzle speed) of 185 m/s.
(a) If the flare is fired at an angle of 55 above the horizontal on the level salt flats of Utah, what is its horizontal range? You can ignore air resistance.
(b) If the flare is fired at the same angle over the flat Sea of Tranquility on the moon, where g = 1.6 m/s2, what is its horizontal range?
I am just going blank i tried solving for range but am lost
Phys.Org News Partner Science news on Phys.org
SensaBubble: It's a bubble, but not as we know it (w/ video)
The hemihelix: Scientists discover a new shape using rubber bands (w/ video)
Microbes provide insights into evolution of human language
OlderDan
OlderDan is offline
#2
Oct8-06, 09:33 AM
Sci Advisor
HW Helper
P: 3,033
Quote Quote by Fanjoni
Resolve the initial velocity into horizontal and vertical components. Use what you know about motion with constant acceleration to figure out how long it will take for an object moving upward with the vertical component of the flare velocity to return to the ground. The horizontal motion of the flare has no effect on the vertical motion, so the time in flight depnds only on the initial vertical velocity and the acceleration. Once you have the time in flight, use the (constant) horizontal component of velocity to figure out how far the flare moves horizontally; that is the range.
Fanjoni
Fanjoni is offline
#3
Oct8-06, 12:18 PM
P: 11
Thanks i finaly got it it took me a while
This is what i did
185*sin55 =V(ertical speed)
V/g = T(ime to stop vertically) T*2=total time
185*cos55 = v(horizontal speed)
t*v=R(horizontal range)
I did the same for the moon g = 1.6
Thanks
Register to reply
Related Discussions
A new angle on the Right Angle Lever Paradox. Special & General Relativity 27
PI gets another shot in the arm... Beyond the Standard Model 0
How does the angle at which a ray of light strikes a prism compare with the angle at Introductory Physics Homework 9
Do you know what's in a flu shot? General Discussion 4
a ball shot at an angle Introductory Physics Homework 3
