Vector Transformation in \mathbb{R}^n and \mathbb{R}^m with Separable Components
  • Context: Graduate
  • Thread starter Thread starter nille40
    Transformation Vector
The discussion focuses on the transformation \(\mathcal{A}: \mathbb{R}^n \rightarrow \mathbb{R}^m\) and its decomposition into three components: the projection \(p\) onto the orthogonal complement of the kernel of \(\mathcal{A}\), the invertible transformation \(\mathcal{B}\) from the complement of the kernel to the image of \(\mathcal{A}\), and the inclusion \(i\) of the image in \(\mathbb{R}^n\). The kernel of \(\mathcal{A}\) is defined as the set of vectors mapped to zero, while the complement consists of vectors not in the kernel. The transformation \(p\) outputs the closest vector to \(x\) that is not in the kernel, and \(\mathcal{B}\) maps vectors from the complement of the kernel to the image of \(\mathcal{A}\).
  • Understanding of linear transformations in vector spaces
  • Familiarity with kernel and image of a transformation
  • Knowledge of orthogonal complements in \(\mathbb{R}^n\)
  • Basic concepts of isomorphism theorems in linear algebra
  • Study the properties of linear transformations and their kernels
  • Learn about orthogonal projections in vector spaces
  • Explore the concept of isomorphism theorems in linear algebra
  • Investigate the relationship between the kernel and image of transformations
Students and professionals in mathematics, particularly those studying linear algebra, vector spaces, and transformations. This discussion is beneficial for anyone looking to deepen their understanding of vector transformations and their properties.
nille40
Hi! I'm in serious need of some help.
I am supposed to show that a transformation [tex]\mathcal{A} = \mathbb{R}^n \rightarrow \mathbb{R}^m[/tex] can be separated into [tex]\mathcal{A} = i \circ \mathcal{B} \circ p[/tex] where
  • [tex]p[/tex] is the projection on the (orthogonal) complement of the kernel of [tex]\mathcal{A}[/tex].
    [tex]\mathcal{B}[/tex] is an invertible transformation from the complement to the kernel to the image of [tex]\mathcal{A}[/tex].
    [tex]i[/tex] is the inclusion of the image in [tex]\mathbb{R}^n[/tex]
I hardly know where to start! I would really like some help. I asked this question before, in a different topic, but got a response I didn't understand. I posted a follow-up, but got no response on that.
Thanks in advance,
Nille
let K be the kernel of B. Then A is K direct sum K*, where we'll use * to denote the complementary vector space.
Let p be the map p(k) = 0 if k in K, and p(x)=x for x in K*, extended linearly. This means that any vector in A can be written as x+k for x in K* and k in K, and then
p(x+k)=x.
This is your projection.
Notice that for all v in A that Bp(v)=v.
The inclusion is the dual construction:
Let I be the image of B. This is a subspace of of R^n. Pick a complementary subspace I*
Then there is a natural map from I to Idirect sum I*, just the inclusion of the vector, call tis map i.
Obviously the map iBp is the same as B.
This is just the Isomorphism theorems glued together.
Hi Nille,
I'd be happy to help you with this problem. Let's break it down step by step.
First, let's define our transformation \mathcal{A}: \mathbb{R}^n \rightarrow \mathbb{R}^m. This means that \mathcal{A} takes in a vector in \mathbb{R}^n and outputs a vector in \mathbb{R}^m. So we can represent \mathcal{A} as a matrix A with m rows and n columns.
Next, let's define the kernel of \mathcal{A}. The kernel of a transformation is the set of all vectors that get mapped to the zero vector in the output space. In other words, it's the set of all x \in \mathbb{R}^n such that \mathcal{A}(x) = 0.
Now, let's define the complement of the kernel. This is the set of all vectors in \mathbb{R}^n that are not in the kernel of \mathcal{A}. In other words, it's the set of all x \in \mathbb{R}^n such that \mathcal{A}(x) \neq 0.
The projection on the complement of the kernel of \mathcal{A} is a transformation p that takes in a vector x \in \mathbb{R}^n and outputs a vector p(x) \in \mathbb{R}^n, where p(x) is the projection of x onto the complement of the kernel of \mathcal{A}. This means that p(x) is the closest vector to x that is not in the kernel of \mathcal{A}. We can represent this as a matrix P with n rows and n columns.
Now, let's define \mathcal{B}. This is a transformation from the complement of the kernel of \mathcal{A} to the image of \mathcal{A}. This means that \mathcal{B} takes in a vector x \in \mathbb{R}^n and outputs a vector \mathcal{B}(x) \in \mathbb{R}^m, where \mathcal{B}(x) is the transformation of x by \mathcal{A}. We can represent this as a matrix B with m rows and n columns.
  • · Replies 34 ·
  • · Replies 52 ·
  • · Replies 21 ·
  • · Replies 26 ·
