How to Find the Speed of a Ball in Horizontal Circular Motion?
The discussion revolves around finding the speed of a ball in horizontal circular motion, specifically when the ball is attached to a rope and spinning at an angle with a given tension. Participants are exploring the relationships between tension, forces, and motion in this context.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the need to draw a free body diagram and consider the forces acting on the ball. Questions arise about how to derive speed from the geometry and forces involved, including the use of trigonometric functions related to the angle of the rope.
Some participants have noted the importance of distinguishing between speed and velocity, while others are attempting to relate the forces from the free body diagram to the equations of circular motion. There is an ongoing exploration of how to connect these concepts without reaching a definitive conclusion.
Participants mention constraints such as prior knowledge from previous lessons and the challenge of recalling relevant equations. The discussion includes references to specific forces like tension and gravity, and how they interact in the context of circular motion.
metalmagik
How would I find the speed of a ball going ina horizontal circle, at angle theta, with length l, and a magnitude of T?
I don't understand how to derive this as speed, could someone help me out?
I assume you mean that the ball is attached to a rope of length l and is hanging from the ceiling and spinning so that the rope has a tension T in it.
You should start out by drawing the geometry of the situation as well as the free body diagram for the ball. How is the ball moving and what forces should be acting on it to make it move that way? What is the source of these forces?
I have drawn an FBD for the ball, but where do I start to get velocity...i realize velocity is an angled vector toward the direction the ball is going next...so do I use the cos and sine of theta to figure out v?
Do you want the velocity or the speed? The velocity is a vector quantity and the speed is the magnitude of that quantity.
Either way you should get the speed first, it's easiest. If you really need the velocity you can figure out which way things need to be pointing later.
Okay, so you drew the FBD, no doubt you noted that the forces acting on the ball in one direction in particular can't possibly be zero. This means that the ball is accelerating. Can you think of something that relates accelerations, circular motion, and speed?
Gah my computer decided to shut down and not start back up again.
Um...acceleration...circular motion...and speed...i don't know. My teacher flung this stuff on us cause we did it last year, but I can't seem to remember anything but mv^2/r.
And the question asks for the speed btw.
[itex]mv^2/r[/itex] is exactly what I was trying to get you to think of :)
Relating that to the horizontal component of the force from your FBD will allow you to come up with an expression for the magnitude of v.
im still so lost haha I still don't know how...its just, [itex]F=mv^2/r[/itex].
How do I make anything of this?
You need the horizontal component of the force from your Free Body Diagram of the ball, that's [itex]F[/itex].
...Tension?
The tension of the rope exerts a force on the mass, yes. Not all of the tension is in the direction of acceleration (horizontal) though.
OH RIGHT ACceleration is the Net Force inwards right??
Acceleration is the net force divided by the mass (F=ma). In this problem you should just assume that the vertical components of the force (from tension and gravity) cancel.
Right...so what about the horizontal? F=ma?
You don't need the acceleration, you're equating the horizontal component of the net force to the force which is required to accelerate the mass in its circular motion.
  • · Replies 29 ·
