| Thread Closed |
Gauge Transformations in Momentum Space? |
Share Thread | Thread Tools |
| Oct12-06, 04:44 AM | #188 |
Gauge Transformations in Momentum Space?mikem@despammed.com wrote: > A different, more recent, area is neutrino oscillations. > Blasone et al have shown that the Fock space of > definite flavour states is unitarily inequivalent to > that definite mass states. See, for example, > hep-ph/9501263, and also the review article by > Capolupo: hep-th/0408228. This means that to > understand the QFT of neutrino oscillations fully, > we need to understand UIRs and disjoint Fock > spaces. OK, let's skip superconductivity and talk about neutrinos. I looked at Blasone-Vitiello paper. This is a good example of what seems confusing about UIR for me. They find a unitary transformation which makes flavor eigenstates (or creation-annihilation operators) from mass eigenstates (or creation-annihilation operators). This transformation also changes the vacuum vector. In particular, it makes the new vacuum |0'> orthogonal to the old vacuum |0>. I have two questions: 1. In my opinion this construction does not mean that the new vacuum lies in a different Fock state. This wouldn't be the case even if all components of |0'> in the old basis were "zero" in the limit of infinite volume. Each of the components may tend to zero, but the number of components tends to infinity. So that if you correctly sum up the infinite number of "zeros" you should still get a vector of unit norm. In my view, this is not dissimilar to the normalized plane wave. The wavefunction of the state with definite momentum is "zero" everywhere in the position space. However, if you integrate its square over the entire universe you should get 1. You wouldn't say that momentum eigenstates lie in a separate Hilbert space, wouldn't you? I think that in order to evaluate correctly the expressions like "zero probability density" x "infinite volume" one should be careful with limits. The "nonstandard analysis" may be useful there. 2. There is an infinite number of unitary transformations from flavor eigenstates to mass eigenstates. Blasone-Vitiello's transformation changes vacuum, which seems unphysical to me. I would prefer to have a unique vacuum without particles of any kind. This is achieved, for example, by the following transformation: U = a_v* a_1 + a_u* a_2 where a_1, a_2 are annihilation operators of the mass eigenstates a_v* and a_u* are creation operators of the flavor eigenstates (e.g., a_v* = cos(phi) a_1* + sin(phi) a_2*) It is 1) unitary in the 0-particle and 1-particle sectors 2) transforms a_1, a_2 to a_v and a_u, respectively 3) does not change vacuum. I am sure I am missing some important point regarding UIR. Could you please let me know what this point is? Eugene. |
| Oct12-06, 04:44 AM | #189 |
| Oct12-06, 04:44 AM | #190 |
| Oct12-06, 04:44 AM | #191 |
| Oct12-06, 04:44 AM | #192 |
| Oct12-06, 04:44 AM | #193 |
| Oct12-06, 04:44 AM | #194 |
| Oct12-06, 04:44 AM | #195 |
| Oct12-06, 04:44 AM | #196 |
| Oct12-06, 04:44 AM | #197 |
| Oct12-06, 04:44 AM | #198 |
| Oct12-06, 04:45 AM | #199 |
| Oct12-06, 04:45 AM | #200 |
| Oct12-06, 04:55 AM | #201 |
Eugene Stefanovich wrote:
> 1. In my opinion [the Blasone-Vitiello] construction does not mean > that the new vacuum lies in a different Fock state. This wouldn't be > the case even if all components of |0'> in the old basis were "zero" > in the limit of infinite volume. Each of the components may tend to > zero, but the number of components tends to infinity. So that if you > correctly sum up the infinite number of "zeros" you should still get > a vector of unit norm. > > In my view, this is not dissimilar to the normalized plane wave. The > wavefunction of the state with definite momentum is "zero" everywhere > in the position space. However, if you integrate its square over the > entire universe you should get 1. You wouldn't say that momentum > eigenstates lie in a separate Hilbert space, wouldn't you? I'm not quite sure what you mean here. My textbooks say that <x|p> = exp(ipx), meaning that a position eigenstate |x> is _not_ orthogonal to a momentum eigenstate |p>. But perhaps you meant something else? > 2. There is an infinite number of unitary transformations from flavor > eigenstates to mass eigenstates. Blasone-Vitiello's transformation > changes vacuum, which seems unphysical to me. I would prefer to have a > unique vacuum without particles of any kind. This is achieved, for > example, by the following transformation: > > U = a_v* a_1 + a_u* a_2 > > where a_1, a_2 are annihilation operators of the mass eigenstates > a_v* and a_u* are creation operators of the flavor eigenstates > (e.g., a_v* = cos(phi) a_1* + sin(phi) a_2*) > > It is > 1) unitary in the 0-particle and 1-particle sectors > 2) transforms a_1, a_2 to a_v and a_u, respectively > 3) does not change vacuum. I stared at this for a while, but I'm still unsure what you mean. Did you omit an "exp" and/or an Integral and/or a "phi" in your definition of U above? >> [...] The basic idea is that every new vector is orthogonal to every >> old vector. Therefore, none of the new vectors can be expressed as >> superpositions of the old vectors. That's essentially what defines a >> UIR. > [...] If I remember well, the idea was to > > 1) apply a unitary tranformation to the vacuum vector |0'> = U|0> > 2) Find components of |0'> in a basis > 3) Observe that in some limit all these components tend to zero > 4) Conclude that the vector |0'> goes outside the original > Hilbert space H in this limit. > > This seems unfair to me. In these examples, even if all components of > |0'> tend to zero, their number tends to infinity, and the sum of > squares of the components |0'> in any basis in H should remain 1. I look at it this way: if we have a (continuously-parametrized, infinite) basis |b> for H, then any other vector |v> can be expressed as an integral superposition, whose coefficients are given by taking the inner product between |v> and each respective |b>, i.e: |v> = Integral db <b|v> |b> So if <b|v> is 0 for every b , the Integral must be 0, showing that |v> cannot be expressed as a superposition of |b>'s. This is quite different from the position/momentum case where <x|p> = exp(ipx) which is non-zero. > The unitary operator U is explicitly defined within the Hilbert space > H, so it is beyond me how it can bring any vector outside of H. If one examines the U carefully, it is not really correct to say that it is explicitly defined "within" the Hilbert (Fock) space. A crucial step in the construction of Fock space is to restrict it to have only state vectors whose total particle number is finite. Without this restriction, one cannot define an inner product on the space, because the usual Riemann-Lebesgue integral calculus doesn't work: we can't approximate an arbitrary vector therein by a countable sum arbitrarily closely, as is necessary when defining integrals rigorously. Umezawa explains (some of) this. But if you can't get a copy, part of it appears in a summary I posted to spr back on 15-Dec-2004 in a thread titled "Degenerate vacua in QFT": http://www.lns.cornell.edu/spr/2004-12/msg0065860.html modulo some followup corrections by Arnold Neumaier. :-) The "U" maps vectors in the Fock space into other vectors in the larger non-separable space, of which the Fock space is but a subspace. The total particle number of those "other vectors" turns out to be infinite, proving that they lie outside Fock space, which by construction contains only vectors of *finite* total particle number. |
| Oct12-06, 04:55 AM | #202 |
| Oct12-06, 04:55 AM | #203 |
| Oct12-06, 04:55 AM | #204 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Gauge Transformations in Momentum Space?
| Gauge Transformations in Momentum Space? | General Physics | 9 | ||
| Gauge Transformations in Momentum Space? | General Physics | 7 | ||
