Glass is a solid material with an amorphous internal structure.
Glass is a solid material characterized by its amorphous internal structure, where atoms are arranged in a disorganized manner rather than in regular patterns. To create glass, materials must be heated above 2000°F and cooled carefully to prevent crystal formation. While eggshells contain calcium carbonate, which can be used in glass mixtures, silica is essential as a "former" to achieve the desired glass properties. Various additives can modify glass characteristics for specific applications, such as enhancing clarity for fiber optics or increasing strength for aerospace uses.
  • Understanding of amorphous materials
  • Knowledge of thermal processing techniques
  • Familiarity with glass composition and additives
  • Basic principles of crystallization and melting
  • Research the role of silica in glass production
  • Explore different types of glass and their applications
  • Learn about bioactive glass and its medical uses
  • Investigate thermal processing methods for glass manufacturing
Materials scientists, glass manufacturers, and anyone interested in the properties and applications of glass in various industries.
KLscilevothma
"glass" is a solid material with an amorphous internal structure.
http://science.nasa.gov/headlines/y2003/14apr_zeroglass.htm
From the article above, it says:
"glass" is a solid material with an amorphous internal structure. The atoms in solids are usually arranged in regular, predictable patterns, like bricks fitted into a wall. But if the atoms are just jumbled together in a disorganized way, like bricks dumped on the ground... that's glass.
Heat them above 2000 F. Then cool the incandescent liquid carefully so that crystals cannot form.
So does it imply that if I have 1kg egg shell, and I heat it to 2000 F and cool it immediately before the atoms arrange themselves regularly again, then I can obtain glass ? Besides how can the atoms just jumpled together in a disorganized way?
Biology news on Phys.org
Yes, that is what is implied. But you only get glass if you could cool it without having crystals form. You couldn't. Not with eggshells alone. Not on earth. Funny you mentioned an eggshell because calcium carbonate in the eggshell is used in some glass-mixtures as a stabilizer (some glass without calcium carbonate can be dissolved by water) but you need to add a "former" to your mix: silica works.
Glass is a mixture of different stuff. Not all mixtures will produce melts, like the article says, though in space crystalization happens less frequently. That was cool. Different stuff is added to the mixture to bring about a desired type of glass. Maybe one that is clearer for fiber-optics (flouride) or stronger for space shuttle windows, etc. There are all sorts of reasons to add this or that.
Anyway, all that author meant with the disorganized analogy was to illustrate that the fundamental property of glass is that when heated it's structurally the same as when cooled. Imagine having hands that are 2700F degrees and being able to squeeze, twist, and melt your lungs AND have them retain that position when cooled without being damaged. Glass can do that. Glass is incredible stuff.
Thanks for the article. I learned some new chemical combinations for glass. The bioactive glass was really interesting for me. I'm going to ask an orthopaedist about that tomorrow.
Cheers,
Istari
10K
11K
