How can I determine the date and time using a Planisphere watch?
  • Context: Undergrad
  • Thread starter Thread starter one_raven
    watch
The discussion revolves around the use of a Planisphere watch for determining date and time based on the positions of stars and celestial bodies. Participants explore the accuracy of the watch at different latitudes, the relationship between star positions and time/date, and techniques for stellar navigation, particularly in the context of both land and sea travel.
  • Homework-related
  • One participant describes the features of a Planisphere watch and questions how latitude affects its accuracy.
  • Another participant explains that while star positions can indicate time or date, they do not uniquely determine both simultaneously due to the repeating nature of star patterns.
  • Some participants discuss the importance of knowing the Sun's position along the ecliptic to determine the date and time.
  • There is a query about using the positions of planets, like Jupiter, to ascertain date and time, with a request for elaboration on this method.
  • One participant expresses interest in stellar navigation and seeks recommendations for educational resources and tools.
  • Another participant mentions the challenges of using stellar navigation on land, particularly in obstructed views, and asks for tips on overcoming these issues.
  • A suggestion is made about using artificial horizons for land navigation and the differences in quality between various sextants.
  • There is a mention of GPS as a simpler alternative to traditional navigation methods.
Participants generally agree on the complexity of determining date and time using celestial navigation, but multiple competing views remain regarding the effectiveness of different methods and tools. The discussion does not reach a consensus on the best approach or the accuracy of the Planisphere watch at varying latitudes.
Limitations include the dependence on specific celestial positions and the challenges posed by geographic features that may obstruct views of the horizon. The discussion also highlights the unresolved nature of how different factors affect navigation accuracy.
This discussion may be useful for individuals interested in astronomy, navigation, and the practical applications of celestial mechanics, particularly those exploring traditional navigation methods in both terrestrial and maritime contexts.
one_raven
I bought a cool new watch with a Planisphere face.
http://shop.store.yahoo.com/imagedesign/planwat1.html
All along the outer ring of the watch face it has the 12 months broken down in five day increments.
There is a dial on the face with a solid shape (something like a crescent moon, but larger).
Around the outside diameter of the crescent it has the times from 6PM to 6AM.
On the crystal there is a sky map showing the major constellations.
When you align the time on the dial with the date around the ring of the face, the crescent represents the earth, and everything that is not covered by it is what is visible in the night sky.
Turn the watch to face north (the directions are on the outer dial) and you have a map of the current visible sky with the horizon at the bottom.
It really is a pretty cool watch.
Anyway, onto the questions...
The planisphere built into this watch is designed for the Northern Hemisphere (between 35 - 50 deg. lat.).
How much is the accuracy affected with each degree of lattitude?
Let's say I designed a planisphere that was 100% accurate on the equator.
If I travel to 60 deg lattitude, how far off would it be?
Is the correction that would have to be made linear? In other words, would I have to make the same level of correction going from 20 deg to 40 deg as I would going from 40 deg to 60 deg, or would the correction be less as I head further towards the pole?
It seems that I could tell the exact date and time by the position of the stars in the sky. It doesn't seem too difficult of a task to create a star calendar/clock if it were stationary, say bolted to the ground in my back yard. Let's say, though, that I were traveling by boat and did not know the what lattitude I was at, could I determine the date and time by star positions?
Or is it that I could find my position if I knew the date and time, or I could find the date and time if I knew my position? Do I need one to determine the other?
Basically this has been a too long post to ask, "How do these darned thingies work?"
Thanks
Astronomy news on Phys.org
The position of the stars do not uniquely identify a date and time, since the star pattern repeats itself every 23 hrs, 56 mins. If you knew the date, you could determine the time and vice versa, but you can't get both just from the stars. The stars look the same at midnight on Jan 1 as they do at 11:56pm on Jan 1, 11:52pm on Jan 2, 11:48pm on Jan 3, etc. Now if you know where the Sun is along the ecliptic, you can figure out the day, and hence, the time as well.
You can always figure out your latitude (in the Northern Hemisphere) by the angle Polaris forms above the horizon. On the equator, Polaris is on the horizon (ignoring atmospheric refraction), at 45 deg N, Polaris is 45 deg above the horizon, and at the North Pole Polaris is at the zenith.
The big problem when traveling by boat (and the one early explorers had until the invention of accurate clocks) is figuring out your longitude. The star pattern at, say, 90 deg W at midnight is the same as the stars at 105 deg W at 1am, and at 120 deg W at 2am. You need to know the date and time in order to find your longitude.
So it boils down to this: If you know the exact date and time, you can figure out your position. If you know your position, you need to know either the date or the time to figure out the other.
Excellent informative reply.
Thank you!
(deleted the rest of this post due to misreasing your last post)
Can you elaborate on that a bit, please?
Also, what about the position of the planets?
For example:
(I know my numbers are probably way off here, but bear with me...)
Let's say that Dubhe is 90 deg above Polaris.
You know that it could be midnight on March 10th.
Or it could be 11:56 on March 11th.
Or 10:00 on April 12th and so on...
If you know where Jupiter is supposed to be througout the year (I just picked Jupiter because it is so easy to spot and my favorite planet ) could you then use that information to determine what the date and time is?
What other techniques are there?
I have always been curious about stellar navigation, but never really started looking into it in depth.
You seem fairly knowledgeable (at least) on the topic, and I am hoping maybe you can give me a bit of a boost in my start.
Do you know of any good educational sites about it?
Or mabe a book that you can highly recommend for beginners?
How does This Beginners Kit look to you?
How much does a $156 sextant really differ from a $1500 one?
Thanks a lot for any more help you can offer!
I should also mention that I plan on using stellar navigation primarily on land.
I know the tools and techinques were designed for seafaring, what things do I need to know?
For example:
Let's say I am on a camping trip in the Pacific Northwest.
If there is a mountain range to my north, it will be difficult to discern where the horizon is.
Is there a trick to that?
there is a device to fake a horizen
most stores that sell sextants will also carry the artifical horizens for land use
or there is a way to use a pan of water
cheap plastic sextants are not as accurate or as well made as a real brass one
optics are the other big price difference ie a real glass lens vs no lens or a poor plastic one
sun-moon filters are allso a difference
cheapies are also venner vs micrometer-drum on the better units
GPS is way eazyer and faster and now cheaper way to go
if you must have a sextant look for an aircraft
one they could be found gov surpluss many years ago, good quality for a very low price
try E-bay as NOBODY uses them anymore in aircraft
  • · Replies 77 ·
10K
  • · Replies 22 ·
