Rotational kinetic energy of a disk
The discussion centers on calculating the kinetic energy of a hanging mass released from a disk. When the disk is dropped, both the disk and mass experience gravitational acceleration, g. The kinetic energy of the mass can be determined using the formula 1/2mv², where v is the velocity of the mass as a function of time or distance fallen. If the mass moves relative to the disk, the difference in velocity must be accounted for, linking it to the disk's angular velocity and moment of inertia.
  • Understanding of rotational kinetic energy and linear kinetic energy concepts
  • Familiarity with the formula for kinetic energy: 1/2mv²
  • Knowledge of moment of inertia and its calculation for a disk
  • Basic principles of gravitational acceleration and free fall
  • Study the calculation of moment of inertia for various shapes, including disks
  • Learn about the relationship between linear velocity and angular velocity
  • Explore the effects of air resistance on falling objects
  • Investigate the principles of energy conservation in mechanical systems
Physics students, mechanical engineers, and anyone interested in understanding the dynamics of rotational systems and energy calculations.
physgirl
ok, so a thread with hanging mass at the end is wrapped around a disk. the disk is dropped and mass is released. how do you find the kinetic energy of the weight at a given time/distance fallen from the disk? I'm not sure to whether use rotational kinetic energy or linear kinetic energy... all the basic values are given, except for the moment of inertia of the disk... so how would I find the kinetic energy of the mass at a given time after its release?
It depends on the what happens when "the disk is dropped and mass is released."
If the disk and mass are dropped together, they are both subject to the same acceleration, g, unless there is more air resistance (force) on the disc.
Obviously, the kinetic energy of the mass if given by 1/2mv2, so one must determine the velocity of the mass as a function of time or distance traveled.
If the mass is moving relative to the disk, then one would need to determine the difference in velocity (speed) of the mass with respect to the rotational axis of the disk, and this speed difference would be manifest in the rotation of the disk, and the differential speed would be related to the angular velocity of the disk.
Note - the acceleration of any mass in 'freefall' is limited by the local acceleration due to gravity.
  • · Replies 21 ·
  • · Replies 33 ·
  • · Replies 19 ·
