Thread Closed
find the shortest distance between 2 non-paralle lines (skew lines) in 3-space
Share Thread Thread Tools
Feb4-04, 05:30 PM   #1
explain how you go about finding the shortest distance between 2 non-parallel lines (i.e. skew lines).
for example:
x=3-2t, y=1-4t, z = t and (x+2)/3=y+1=(z+1)/-2
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Feb4-04, 06:58 PM   #2
Recognitions:
You can work out the details.
1. Take the cross product of the two lines.
2. Construct a plane perpendicular to this vector.
3. Project the two original lines onto this plane.
4. Find the point of intersection of the two projections.
5. Find the points on the original two lines which projected onto the intersection point.
6. Find the distance between these points. That's what you are looking for.
Feb4-04, 07:39 PM   #3
Recognitions:
Since this is the calculus forum, here is an alternate approach to my previous note.
1. Represent both lines in parameter form (s and t).
2. Set up the distance squared (H) between arbitrary points p on line 1 and q on line 2 as a function of the two parameters.
3, Take partial derivatives of H with respect to t and with respect to s. This will be two linear equations in two unknowns s and t.
4. Solve for s and t. Find the points on the 2 lines corresponding to these values of s and t and compute the distance between them.
5. If you are not interested in the points on the lines but only the distance, plug the found values of s and t into the equation for H and take a square root.
Feb4-04, 10:23 PM   #4
i found a very simple, basic and easy to understand solution on the web, take a look if you like:
http://www.mis.coventry.ac.uk/jtm/slides/8/sld8p5.pdf
Oct7-07, 10:13 PM   #5
I like this approach for its simplicity and symmetry:
1. Normalize-Cross-Prod the directions of L1 and L2 to obtain the direction of their adjoining lineSeg dL
2. Extrude L1 along direction dL (= plane PL1)
3. Extrude L2 along direction dL (= plane PL2)
4. The endpoints of the shortest LineSeg bridging between L1 and L2 are:
intersection( PL1 , L2 )
intersection( PL2 , L1 )
from Pierre Bierre, author, "Flexing the Power of Algorithmic Geometry"
Thread Closed
Thread Tools
Similar Threads for: find the shortest distance between 2 non-paralle lines (skew lines) in 3-space
Thread Forum Replies
Find the equivalent intersection point of multi lines in 3D space General Math 3
Are all lines through space also loops? Cosmology 10
Find slope of 2 perpendicular lines Precalculus Mathematics Homework 11
Perpendicular Lines in 3 Space Calculus & Beyond Homework 7
Force Lines and Equipotential lines Introductory Physics Homework 1
