Recoil may eject black holes from a galaxy
The discussion centers around the concept of gravitational wave recoil and its potential to eject black holes from galaxies or globular clusters following their merger. Participants explore theoretical implications, speculative scenarios, and the physics underlying the phenomenon, referencing both scientific literature and fictional representations.
  • Some participants discuss the mechanism of gravitational wave recoil, noting that it occurs when two black holes merge asymmetrically, imparting velocity to the resulting black hole.
  • One participant expresses skepticism about the conservation of momentum in the context of the recoil, questioning how the momentum is balanced during the merger process.
  • Another participant references a science fiction novel, suggesting a fantastical interpretation of black hole dynamics, which contrasts with the scientific explanations provided.
  • Several participants share links to research papers that discuss the dynamics of black hole mergers and the implications of gravitational wave emissions.
  • There is mention of observational evidence supporting the theory of black hole recoil, although some participants express doubt about the reliability of this data.
  • One participant articulates a general skepticism about the implications of the theory, suggesting that it leads to an unsettling view of the universe.
  • Another participant argues that the existence of gravitational wave recoil is consistent with established physics, emphasizing that the effect is plausible given current theories.
Participants express a range of views, with some supporting the theoretical framework of gravitational wave recoil while others remain skeptical or critical of its implications. There is no consensus on the validity of the theory or the interpretations of the data presented.
Participants note limitations in understanding the full implications of gravitational wave recoil, including the complexity of momentum conservation during black hole mergers and the speculative nature of some interpretations. The discussion reflects a mix of established physics and speculative ideas.
marcus
Dearly Missed
I hadnt heard of GW recoil imparting velocity to a black hole.
http://www.arxiv.org/astro-ph/0402056
"How Black Holes Get Their Kicks..."
It's an article by three people, from Cornell, MIT, and Chicago.
When two black holes spiral in and merge, linear momentum is carried off asymmetrically by a burst of gravitational waves at the end
unless the two holes have equal mass (which one wouldn't expect them to have)
and this one-sided burst of GW produces a "recoil" which can give
the resulting black hole a velocity big enough to take it out
of the galaxy or globular cluster it belongs to
would not have expected this, their explanation of it is interesting
the effect was first predicted in 1982
Astronomy news on Phys.org
I have heard of a simulacrum of this idea, which is described in the novel Moonseed, by Stephen Baxter. Two celestial bodies, Venus and, er, I shall not spoil it for you, blow up from the effect of nano-machines or something. The after-effects of the cataclysmic destructions leave black hole "boosters". The black holes would be moving at the speed of light, and sweep up anything in their paths. At the end, pioneers use the black holes to travel approximately 300,000 kilometers per second and colonize the galaxy.
Now that would certainly make a trip to the Andromeda galaxy easier, but at such a tremendous price! (Again, I refrain in revealing of too much data. Read the book.)
:smile:
in this article the recoilspeeds produced by the holes falling together are only a few hundred kilometers per second.
it's a conventional journal article by conventional astrophysicists
but I have to confess that the conclusion seems bizarre to me
do you understand their explanation
it is peculiar because the center of mass of the two holes
starts out basically standing still
then they merge and suddenly the combined hole is moving off to the left at several hundred km/second. what happened to Conservation of
Momentum?
where did all the momentum come from?
what did they send moving off to the right so it would have equal and opposite momentum? what takes the place of rocket exhaust?
the recoil momentum comes from sending a burst of gravitational waves off to the right.
but it has to be an extremely powerful pulse to carry the same momentum as stellar-mass black holes moving hundreds of km/sec.
if your scifi author figured out how to make that happen, more power (and momentum) to him
(Apparently) The momentum for the black holes came from some GUT/Dimension-Unfolding power. It goes pretty deep in the book, but the info I have is shallow. I'd suggest reading Moonseed, as the black hole booster theory occurs many times in the book.
MARCUS, you may be interested in these two urls, i hope they
go some way in answering your question, the first one is
mosty graphs
http://www.mpia-hd.mpg.de/THEORY/COG02/talks/merritt.pdf
http://www.iafe.uba.ar/astronomia/mirabel/aa2903.pdf
I looked at "Dynamics of BH Nuclei" by David Merritt and it covers a lot of ground, with plenty of pictures. Thanks for the link.
Yes. There could be hundreds of stellarmass BHs zooming around.
the momentum comes during the final plunge together. as some of these people explain.
they spiral around each other radiating off energy with GW and then they go faster and faster and radiate off a huge burst and abruptly fall in together. And at that point it is not symmetric (because one is more massive, unless they just happen to be the same mass) and in that plunge ONE of them accelerates more and GW is radiated in a lopsided way
so that carries momentum off in one direction and gives a recoil kick
so the merged black hole is flying in the opposite direction with enough speed so it could leave a small galaxy or a globular cluster
this is extremely strange to me but the people who are expounding it seem to be reasonable well-qualified people.
so I have to accept the idea that in the universe there are black holes zooming around which are big enough to eat the Earth for breakfast. it is not a comforting thought
Originally posted by wolram
two more i dug out of my collection, did you know that
there could be hundreds of these things zooming
around the universe?
http://relativity.livingreviews.org/Articles/lrr-2002-2/articlesu13.html
http://aa.springer.de/papers/7324003/2300888/sc4.htm
none of this makes me happy, it just seems totally wrong,
but it seems there is some observational evidence to re enforce
the theory, could there be some error in the data?
i have had a little time to think about this and in my
ever skeptical way have decided its a load of old
cods wallop sorry if i am not scientific with my
thoughts.
http://arxiv.org/PS_cache/astro-ph/pdf/0402/0402057.pdf
ABSTRACT
Coalescing binary black holes experience an impulsive kick due to anisotropic emission of gravitational waves.
We discuss the dynamical consequences of the recoil accompanying massive black hole mergers. Recoil velocities
are sufficient to eject most coalescing black holes from dwarf galaxies and globular clusters, which may
explain the apparent absence of massive black holes in these systems.
this is the best explanatory paper i can find and is worth
reading its only a couple of pages.
by a nice coincidence, they begin by referring to the paper I linked to at the start of the thread. It is by 3 of the authors who wrote this one.
1. Kick Amplitude
In a companion paper (Favata, Hughes & Holz 2004; hereafter
Paper I), the amplitude of the recoil velocity experienced
by a binary black hole (BH) due to anisotropic emission
of gravitational radiation during coalescence is computed.
the "companion paper" by Favata, Hughes, Holz
has a reasonably clear description of how the
anisotropy ("lopsidedness") of the radiation arises,
mostly during the final plunge
thoughts.
Why?
Everything they talk about is normal physics. That the effect exists isn't hard to guess. Gravitational radiation can carry away linear momentum, so its reasonable that a strongly radiating asymmetric system would do this. The contribution of this paper is more about showing exactly how large the effect is.
quote, stingray.
i know my comment is not justified, but have you ever
thought our grasp on reality is slipping, ok these things are
possible given our present theories are correct, but
i have doubts, if we take everything we are told for granted
then our universe is ever more strange and hostile to life.
the next decade is probably going to be the turning point in our
theories of gravity and how our universe works, but i will
remain skeptical until we have proof of what gravity is,
may be my view is unscientific and i am in a minority but this
doesn't worry me, when gravitational radiation is detected i
fall in line.
the second of these two articles demonstrates that not everything
is black or white, a slip with the numbers gave birth to a BH
now they are not sure.
http://www.space.com/scienceastronomy/astronomy/blackhole_010913.html
Conducting a bit of astronomical archaeology, researchers have dug up 43-year-old photographic evidence of an ancient black hole and used the information to learn that the object has been wandering at high speed on an odd, looping path through the Milky Way Galaxy for 7 billion years.
20 jan 2003.
http://www.space.com/scienceastronomy/blackhole_trick_030120.html
It turns out there may not even be a black hole in the star cluster, called M15, a separate team of astronomers now says. Instead, a more plausible explanation is that the central region of M15 is a mass cosmic grave
Ok, fair enough. Even if GR is wrong though, I doubt that the alternative would lack gravitational waves. Almost any theory you try to write down would have them (of course the numerical predictions would be different in every case) unless you go with action-at-a-distance type models.
I also don't see this as being very hostile to life. It wouldn't be a very common process, and it would still be very unlikely that any wandering object would get near enough to do any damage. The threat of a nearby supernova is probably much worse.
quote stingray.
action at a distance sounds implausible but i wouldn't
rule out the possibility of some kind of entanglement
I'm not exactly sure what i mean by this an don't want
to join the crackpot brigade, i can only wait for
evidence of gravitational radiation, but what if
it is not found?
  • · Replies 20 ·
  • · Replies 19 ·
