Thread Closed
Line integral and path dependence question
Share Thread Thread Tools
Oct16-06, 01:38 PM   #1
Given F = iy - jx (this is my first post; not sure how you do vector notation here but I'm showing vectors in bold - hope that works). The problem is to show that this is a non-conservative force by integrating from the origin to (1,1) (ie, the path is y=x), and then do it again from the origin to (0,1) and from there to (1,1).
I just don't get how to set up the integrals - can someone help? I understand the concept behind the line integrals, but hit a brickwall trying to apply it. Thanks.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Oct16-06, 01:44 PM   #2
[tex]_C\int_{A}^{B}\vec{F}.d\vec{r}[/tex]
The first part is quite simple - direct substitution. For the second part, what are x and dx =? when you go from (0,0) to (0,1)?
Oct16-06, 02:06 PM   #3
Sorry, I don't know how to show integrals in here, but what I believe you do is that F remains the same, and you dot it with dr, which will be (dx,0) for the path from (0,0) to (0,1), and (0,dy) for the path from (0,1) to (1,1). Right so far?
Oct16-06, 02:25 PM   #4
Quote by Old Guy
Refer to this http://www.physicsforums.com/showthread.php?t=8997
You're right about the differentials, but what about x and y along those paths?
Oct16-06, 02:43 PM   #5
Thanks for the reference. And I think you've hit on what I don't get - what about x and y? F is the same regardless of path, isn't it? So what's the point (and how is it calculated)? I think that's what I"m missing.
Oct16-06, 02:48 PM   #6
F = yi - xj, but what's y equal to when you're on the x-axis; in other words, when moving from (0,0) to (0,1)?
Oct16-06, 02:53 PM   #7
y=0 along the x-axis
Oct16-06, 02:54 PM   #8
EDIT: Sorry, I've been confusing coordinates here. When you're moving from origin to (0,1) dx = 0 and x =0...it's along the y-axis. I apologise.
Oct16-06, 03:06 PM   #9
I'm not clear on what the question is now . . .
Oct16-06, 03:13 PM   #10
Okay, here's how you do it for the path from (0,0) to (0,1)
[tex]\int_{(0,0)}^{(0,1)}(y\hat{i} - x\hat{j}).(dx\hat{i} + dy\hat{i})[/tex]
But since you're moving along a path in which x is a constant, in this case, zero, the above reduces to...
[tex]\int_{y=0}^{y=1}(ydx - xdy) = 0[/tex] (x = 0 and dx = 0)
Is that clear?
Oct16-06, 03:16 PM   #11
Yes, I got that.
Oct16-06, 03:24 PM   #12
And I also don't understand how this could come to 0, because the particle was moved over a finite distance by a force - SOME amount of work should have been done!
Oct16-06, 03:39 PM   #13
Not necessarily. The work can be zero even in simple circumstances such as carrying a box ("horizontally"). There is a force, the box was moved through a finite distance, yet no (physical) work was done.
When you consider line integrals such as the above, which is a generalisation of the formula W = F.d, you evaluate the work at every point along the path, and then add it all up. It can be positive, negative, or zero.
Oct16-06, 03:43 PM   #14
Right, I do recall that. On this problem, however, the work seems to calculate to 0 for either path, which would imply the force is conservative, which my book says it is not (and I also calculated curl F to confirm this). What am I missing here?
Oct16-06, 03:45 PM   #15
Did you calculate the integral from (0,1) to (1,1)?
Oct16-06, 03:53 PM   #16
Yes; it was also 0.
Oct16-06, 03:56 PM   #17
Can you show your work?
Thread Closed
Thread Tools
Similar Threads for: Line integral and path dependence question
Thread Forum Replies
Question on quadratic fluctuations in the path integral formalism Quantum Physics 1
line integral question Introductory Physics Homework 4
Quick Path Integral Question Quantum Physics 4
A question about Hawking's path integral methods Quantum Physics 4
Weird Path Integral question General Physics 1
