The discussion revolves around the light clock thought experiment involving parallel moving mirrors, exploring the implications of different photon entry angles and the resulting time measurements from both the lab frame and the moving train frame. The scope includes theoretical considerations of time dilation and the nature of light clocks in special relativity.
- Exploratory
- Debate/contested
- Technical explanation
- One participant suggests that when a photon enters the train perpendicular to the mirrors, the lab observer sees a straight path while the train observer sees a zig-zag path, leading to different time accumulations on their respective clocks.
- Another participant argues that if the photon enters from above and travels straight down, it will miss the lower mirror due to the train's motion, resulting in a longer time measurement for the train observer compared to the lab observer.
- A participant challenges the common assertion that "each observer sees the other guy's clock as running slow," stating that the clock that accumulates more time depends on the specifics of the experiment and the spacetime intervals involved.
- One participant emphasizes that the definition of a light clock requires the photon's lateral progress to be zero relative to some observer, and if this condition is not met, it cannot be considered a light clock.
- Another participant presents a hypothetical scenario involving a long train traveling at a significant fraction of the speed of light, questioning the time recorded by the trainman versus the lab observer and suggesting that something seems amiss in their calculations.
- A correction is made regarding the time recorded by the trainman, indicating that it should always be less than the proper time measured in the lab, raising further questions about the validity of the assumptions made.
- One participant asserts that time dilation should be understood as a comparison of clock rates measured from one frame rather than a direct comparison from both frames simultaneously.
- A later reply discusses the decay of muons in different frames, illustrating the concept of time dilation through a specific example, but does not resolve the ongoing debate about the light clock scenario.
Participants express differing views on the implications of the light clock thought experiment, with no consensus reached on the correct interpretation of time measurements or the nature of time dilation in this context.
Participants note various assumptions, such as the length of the mirrors and the conditions under which the photon travels, which may affect the outcomes of their analyses. The discussion remains open-ended with unresolved mathematical steps and interpretations.
