Thread Closed
Finding diameter of a wire based on the current and current density.
Share Thread Thread Tools
Oct17-06, 11:00 PM   #1
Exclamation
You need to design a 0.9 A fuse that "blows" if the current exceeds 0.9 A. The fuse material in your stockroom melts at a current density of 540 A/cm2. What diameter wire of this material will do the job?
540x10^-2=5.40 A/m^2
5.40= .9/x
Solving for x gives the answer: .166666666666667
Then:
.166666666667=pi(r^2)
sqrt(.166666666667/pi)=r
The result of that answer multiplied by 2 gives 4.607m. The answer asks for it in mm so I converted to 460.7mm and it says its wrong. Where did I go wrong, I'm just using the current density formula: J=I/A
Where J is the current density
I is the current
A is the area
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Oct18-06, 12:22 AM   #2
Recognitions:
Homework Helper Homework Help
Quote by mkienbau
5.40= .9/x
Then:
I is the current
A is the area
Do what you did again, only this time keep track of your units every step along the way. Unit consistency will do wonders for you.
Thread Closed
Thread Tools
Similar Threads for: Finding diameter of a wire based on the current and current density.
Thread Forum Replies
Current and Current Density Introductory Physics Homework 2
Current in a Wire. Introductory Physics Homework 5
Current Density and Current Introductory Physics Homework 1
Current through wire problem Advanced Physics Homework 2
Aluminum wire, current, voltage, density, find mass Introductory Physics Homework 5
