Problem with Differentiation Using Quotient Rule
The discussion focuses on finding the second derivative of the function h(x) = [(x^2)-1] / [2x-(x^2)] using the Quotient Rule. The first derivative is correctly calculated as h'(x) = [2(x^2)-2x+2] / [2x-(x^2)]^2. However, the second derivative h''(x) = [2x(4(x^5)-5(x^4)+(x^3)+20(x^2)-16x+4)] / [2x-(x^2)]^4 is deemed incorrect and overly complex. Simplification is necessary, particularly by factoring out (2x-x²) to streamline the result.
  • Understanding of the Quotient Rule in calculus
  • Familiarity with derivatives and their graphical interpretations
  • Ability to simplify algebraic expressions
  • Experience with graphing calculators or software for verification
  • Learn advanced techniques for simplifying derivatives in calculus
  • Explore graphing software options for visualizing functions and derivatives
  • Study the implications of critical points in the context of second derivatives
  • Review examples of applying the Quotient Rule to complex functions
Students and educators in calculus, mathematicians focusing on differentiation, and anyone seeking to improve their skills in deriving and simplifying complex functions.
PianistSk8er
I am attempting to find the second derivative of a function:
I proceeded by using the Quotient Rule, and I found the following as the first derivative. (It is correct.)
h`(x) = [2(x^2)-2x+2] / [2x-(x^2)]^2
Next, I tried using the Quotient Rule again, and I found a very long result. I simplified the result and obtained the following:
h``(x) = [2x(4(x^5)-5(x^4)+(x^3)+20(x^2)-16x+4)] / [2x-(x^2)]^4
Is this correct? And, if so, how can I proceed from here? (The answer in the book seems to have been simplified a lot more than this one.
Thanks in advance!
Nico
Not correct, I'm afraid. You'll need to check your working.
One way of checking if your answers are correct is to graph them, using a graphing calculator or software.
h'() is the slope of h(), and h''() is the slope of h'().
If you plot h'(), you will find it has a minimum at about x = 0.8. That means its slope, the h''() curve, is zero at about x = 0.8. So if you plot h''(), and it cuts the x-axis at about x = 0.8, then that is reasonable confirmation that you may have the right answer.
Also, when doing the 2nd derivative, you should get a common factor of (2x-x²) that cancels out top and bottom. This will simplify things a bit.
  • · Replies 25 ·
