Calculating Tension in a Pulley Weight System
  • Thread starter Thread starter konichiwa2x
    Pulley Weight
The discussion focuses on calculating the tension in a pulley weight system where two weights, W1 and W2, are suspended from a light string over a smooth fixed pulley. When the pulley is accelerated upwards at 'g', the tension in the string is determined using the formula \frac{4w_{1}w_{2}}{w_{1} + w_{2}}. The participants clarify that both masses will experience upward acceleration equal to 'g', which contributes to the additional tension in the string.
  • Understanding of basic physics concepts such as tension and acceleration.
  • Familiarity with pulley systems and their mechanics.
  • Knowledge of Newton's laws of motion.
  • Ability to manipulate algebraic equations for solving physics problems.
  • Study the effects of varying weights on tension in pulley systems.
  • Learn about the dynamics of non-accelerating versus accelerating pulleys.
  • Explore real-world applications of pulley systems in engineering.
  • Investigate advanced topics such as friction in pulley systems and its impact on tension.
Students of physics, mechanical engineers, and anyone interested in understanding the dynamics of pulley systems and tension calculations.
konichiwa2x
Two weights W1 and W2 are suspended from the ends of a light string passing over a smooth fixed pulley. If the pulley is pulled up at an acceleration 'g', then what will be the tension in the string? Solution : [te
x]\frac{4w_{1}w_{2}}{w_{1} + w_{2)}[/tex]
I have calculated that the tension in the spring assuming that the pulley is not accelerating. I know to find the acceleration also(if the pulley is not acclerating). How do I proceed?
thanks for your time.
Hint: both the masses will be accelerated upwards at g. So what will be the additional tension in the string.
thanks! I got it.
  • · Replies 27 ·
  • · Replies 18 ·
  • · Replies 18 ·
  • · Replies 22 ·
  • · Replies 22 ·
  • · Replies 22 ·
