E = mc2 is not really true in all cases?
  • Context: Graduate
  • Thread starter Thread starter jainabhs
The discussion revolves around the validity of the equation E = mc² in various contexts within special relativity (SR) and general relativity (GR). Participants explore scenarios where this equation may not hold true, addressing concepts such as relativistic mass, energy density, and the implications of non-closed systems.
  • Some participants assert that E = mc² is not universally applicable, particularly in non-closed systems, where energy may not relate directly to mass.
  • One participant explains that for an object moving with velocity v, its energy in a different frame can be expressed as E = mc²/γ, where γ is the Lorentz factor.
  • Another participant discusses the general law of energy in SR, E² = p²c² + m²c⁴, noting that for massless particles, E = pc, while for massive particles, E = mc² holds in their rest frame.
  • There are references to historical concepts such as "relativistic mass" and how current terminology has shifted to focus on invariant mass.
  • A participant mentions that energy density and mass density are not identical, cautioning against common misconceptions.
  • One participant provides links to external resources for further explanation of cases where E does not equal mc², including examples involving non-closed systems.
  • Another participant raises a question about differing definitions of relativistic mass found in literature, indicating ongoing debate in the community.
Participants express differing views on the applicability of E = mc², with some agreeing on its limitations in specific contexts while others challenge the notion that it is not universally valid. The discussion remains unresolved with multiple competing perspectives presented.
Participants highlight limitations in definitions and assumptions regarding mass and energy, particularly in non-inertial frames and non-closed systems. The discussion also reflects a historical evolution in terminology and understanding of relativistic concepts.
This discussion may be of interest to students and enthusiasts of physics, particularly those exploring the nuances of special and general relativity, as well as professionals engaged in particle physics and related fields.
jainabhs
E = mc2 is not really true in all cases??
I am new to the field of SR and GR so my knowledge is not much but in the last thread I red following .
"That is an incorrect statement. It assumes that E = mc2 in all cases, which it does not. It therefore "relativistic mass" cannot be replaced by "mass-energy". This assumption can lead a person to make statements which are very serious errors. E.g. people will almost always believe that mass density is identical to energy density. It is not. Rindler explains this in his 1982 intro to SR book."
So please explain, E = mc2 is not really true in all cases, in which cases this doesn't hold true.
Two answers, which are consistent with one another:
1. If I look at an object which is moving with a velocity v with respect to me, and somehow I measure its energy, in my frame, then its energy will be [tex]\gamma E[/tex], where E is its energy in its own frame, and [tex]\gamma = \frac {1}{\sqrt{1 - \frac{v^2}{c^2}}}[/tex]. So if I equate this to [tex]mc^2[/tex] then [tex]\gamma E = mc^2[/tex] or [tex]E = \frac{mc^2}{\gamma}[/tex].
2. The general law of energy for particles in SR is
[tex]E^2 = p^2c^2 + m^2c^4[/tex] (p is the magnitude of the three momentum), so for a massless particle (m=0 in its own frame), the second term drops out and we would have [tex]E = pc[/tex]. On the other hand, for a massive particle in its own frame, the first term drops out (in its own frame its momentum is zero), and we have [tex]E = mc^2[/tex].
Both answers give you the same info: the famous equation refers to a massive particle in its own rest frame. In all other cases the law is subject to relativistic corrections. This is not at all academic, either. Particle physicsts have to use these relatiionships in calcualting the effects of the fast moving paricles in their experiments.
the notation we used when i was in school 3 decades ago was
[tex]E = T + E_0 = \frac{m_0 c^2}{\sqrt{1 - \frac{v^2}{c^2}}} = m c^2[/tex]
where [itex]T = E - E_0[/itex] is the kinetic energy (which depends on whose frame of reference you are in), [itex]E_0 = m_0 c^2[/itex] is the rest energy (the "energy in its own frame") and [itex]m_0[/itex] is the rest mass or the apparent mass in the frame of the body (also called "invariant mass"). we also were presented with the out of vogue concept of "relativistic mass"
[tex]m = \frac{m_0}{\sqrt{1 - \frac{v^2}{c^2}}} \ge m_0[/tex]
so [tex]E = m c^2[/tex]
can hold in all cases with [itex]E[/itex] and [itex]m[/itex] both having corresponding meaning in the same frame. if [itex]m[/itex] is rest mass, than [itex]E[/itex] is rest energy. we were able to equate this [itex]E[/itex] (total energy, the sum of kinetic and rest energies) to the same [itex]E[/itex] that relates particle energy to wave function frequency:
[tex]E = h \nu = \hbar \omega[/tex]
resulting in an apparent inertial mass of
[tex]m = \frac{E}{c^2} = \frac{h \nu}{c^2}[/tex]
and given that relativistic mass we always defined momentum to be
[tex]p = mv[/tex]
and assuming that photons always move at a speed of [itex]c[/itex] for any reference frame, then the momentum was simply
[tex]p = mv = \frac{h \nu}{c^2} v = \frac{h \nu}{c}[/tex]
and we got the same expression (keeping notational consistency):
[tex]E^2 = p^2 c^2 + m_0^2 c^4[/tex]
but this notation has evidently been frowned on in current times. now [itex]m[/itex] always seems to mean only "rest mass" (what we used to call "[itex]m_0[/itex]") and there is no "relativistic mass" to talk about.
we didn't call photons "massless", we said only that their rest mass was 0.
Explaining it is not quite that easy. For this reason I created a two web pages to give a proper explanation of why E does not always equal mc2. The case when it does hold is for a isolated system. If you have a rod and you squeeze it from the ends then this is not a closed system and the energy is not related to mass by E = mc2. Please see the following for why this is true
Explanation
http://www.geocities.com/physics_world/sr/mass_momentum_density.htm
Example #1
http://www.geocities.com/physics_world/sr/inertial_energy_vs_mass.htm
Example #2
http://www.geocities.com/physics_world/sr/mass_mag_field.htm
Example #3 - (Published by Wolfgang Rindler et al in the American Journal of Physics)
http://www.geocities.com/physics_world/sr/rd_paradox.htm
Also, the proper mass of an object which is not a closed system (e.g. a box that radiates two photons) is not related to the energy by m2c4 = E2 - (pc)2 which is the magnitude of the 4-momentum. For expaination please see the bottom of the following web site, the section labeled An Incorrect Application of Invariant Mass
http://www.geocities.com/physics_world/sr/invariant_mass.htm
Best wishes
Pete
ps - I can scan that part of Rindler's text in which explains this and e-mail it too you if you'd like.
I also forgot to mention that "relativistic mass" is the time-component of the 4-momentum. To see its general form (in time orthogonal fields) please see Eq. 14 at
http://www.geocities.com/physics_world/gr/force_falling_particle
When the system of coordinates corresponds to that of a non-inertial frame of reference (i.e. a gravitational field) then it the time-component of the 4-momentum is no longer proportional to the energy of the particle and once again we do not have an equality. The energy is always proportional the time-component of the 1-form corresponding to the particle's 4-momentum.
Best wishes
Pete
In
https://www.physicsforums.com/showthread.php?t=138968
(in section 3 and in appendix A)
I described different view on relativistic mass. I hope on visit and discussion.
jainabhs - I recently received a paper from an acquaintance of mind which makes me question my assertion that E does not always equal mc^2. There seems to be two definitions floating around in the physics literature by some very respectable relativists on both sides of the claim. I walked through the derived one author gave with a fine toothed comb. I found it a solid argument and one that appeared to be agreement with a paper by Einstein himself. It will take me sometime to review all this literature so I'm placing my opinion on this on hold until I walk through this new definition very carefully. It will take a while since this is not the only project I'm working on at this time.
Best wishes
Pete
exponent137 said:
In
I wish I could but for now I'm swamped with work. Perhaps we could discuss it in PM? I will probably leave this forum soon due to a certain problem which arose yesterday but will check in every now and then to check my PM. However that seems like a long paper so I may not dig into it deeply for several weeks. But after that I would be able to give it more attention. I'm writing a new version of a paper I wrote on this subject so it is in my best interest to read your work. :smile:
Best wishes
Pete
information request
exponent137 said:
In
how could I see the paper you mention? you do not answer messages you receive?
sine ira et studio
  • · Replies 48 ·
9K
  • · Replies 23 ·
11K
  • · Replies 18 ·
  • · Replies 0 ·
  • · Replies 0 ·
