Amplitude and phase of a Feynman path
The discussion revolves around the relationship between the amplitude and phase of paths in the Feynman path integral and their geometric attributes. Participants explore whether these attributes can be connected to concepts such as path length, curvature, and deviation from geodesics, while considering the implications of integrating over a space of field configurations.
  • Some participants propose that the amplitude and phase of paths in the Feynman path integral may be connected to geometric attributes such as path length and curvature.
  • Others argue that since the paths are through a space of all field configurations, which is not a Riemannian manifold, terms like "length" and "curvature" are inappropriate.
  • It is suggested that the phase increases at a steady rate along each path, and that paths far from the stationary one cancel out in the path integral.
  • Some participants assert that each path has an equal amplitude, while the phase is determined by the action along the path in units of Planck's constant.
  • There is a discussion about the action integral and its relationship to path length, with some questioning whether the action for different fields can be interpreted in terms of length.
  • One participant emphasizes the importance of summing over all paths, suggesting that the coupling of paths is fundamental to quantum mechanics.
  • Another participant raises a question about what is meant by the "coupling" between all possible paths.
Participants express multiple competing views regarding the geometric interpretation of paths in the Feynman path integral. There is no consensus on whether geometric attributes like length and curvature are applicable in this context, and the discussion remains unresolved.
Limitations include the dependence on definitions of geometric terms in a non-Riemannian context, and the unresolved nature of how the action relates to path length in different field configurations.
Mike2
Can the amplitude and phase associated with each of the paths in the Feynman path integral be connected to geometric attributes of that path? For example, is the amplitude and phase connected to how long the path is or how much it curves or how much it deviates from the geodesic?
these are paths through the space of all field configurations, which is not a Riemannian manifold, so the words "length" and "curvature" and "geodesic" are out of place here.
The phase increases at a steady rate along each path. That is the only criterion. Then when the paths are summed up in the path integral, the phases of paths far from the stationary one cancel.
So it would seem that phase is related to the length of the path. What about amplitude?
1) Each separate path has an equal amplitude
2) The phase for each path is the action along the path in units of Plank’s constant
you're not listening. you are integrating over a space that does not have a metric, so you cannot ask the length of the path, nor the curvature.
Excuse me Lethe, but isn't there a nuance here? Each of the paths in the space-of-paths is a PATH, in euclidean space, and in that space it does have a length. And indeed it is in that space that the physics happens that is attributed to the path when you integrate over the space-of-paths. N'est-ce pas?
the space of all field configurations is a Euclidean space? why do you say that? for starters, it is certainly infinite dimensional, and Euclidean space is finite dimensional.
tell me what expression you want to represent the length of a path through the space of field configurations. the action?
Isn't the phase determined from the Action Integral, and isn't the action integral proportional to the length?
the action for a relativistic point particle traveling on a Lorentzian manifold is proportional to the length of its worldline.
but the action for, say, a scalar field? as far as i can tell, this not the length.
Is the amplitude of related Feynman paths normalized over actions which generally contrast between their domain magnitudes ("lengths"), but retain a constant phase difference?
Action
[tex]S = \int_{t_0}^{t_1} L \ dt[/tex]
where S = the classical action
L = the lagrangian
Action of a scalar field
[tex]S = \int_{t_0}^{t_1} \int_{V} L \ d^3V \ dt[/tex]
but in this case L = the lagrangian density.
The probability amplitude for a given path is [tex]A e^{i S}[/tex], where A is some constant that is chosen so that when you sum over all paths the total probability adds up to one and S is the action along that particular path. Remember that A is the same for ALL paths.
Ahh you forget the all important summation sign, in front of that expression, I insist it makes no sense physically to talk about one path, even in principle! Unless you are in a very restricted world =)
Its the coupling of all possible paths, in exactly that way, that is the fundamental quantum *thing*!
What is the "coupling" between all possible paths?
Integration over. The paths then occupy the role that points do in elementary integration.
Originally posted by MathNerd
Action
L = the lagrangian
So it would seem that it is the Lagrangian that chooses the classical path out of all the possible paths by determining how the phases will add to produce the classical result. And the Lagrangian must comply with the Euler-Lagrange equation which some interpret as a vector always normal to the path. What does this all prove?
  • · Replies 18 ·
  • · Replies 57 ·
  • · Replies 33 ·
