Bernoulli Principle: Intuitive Explanation?
The discussion centers on the intuitive understanding of the Bernoulli Principle, particularly in the context of fluid dynamics within a venturi tube. The user seeks a clearer mental visualization of how reduced pressure occurs as fluid approaches the narrowest point of the tube. Key concepts include the representation of fluid force as "arrows of force," illustrating how moving air exerts pressure at an angle, resulting in lower pressure compared to still air. The user emphasizes the importance of dynamic energy and its relationship to kinetic energy in grasping the principle.
  • Understanding of fluid dynamics principles
  • Familiarity with the Bernoulli Principle
  • Basic knowledge of kinetic energy concepts
  • Visualization techniques for physical forces
  • Research the application of the Bernoulli Principle in venturi meters
  • Explore fluid dynamics simulations using software like ANSYS Fluent
  • Study the relationship between pressure and velocity in fluid flow
  • Learn about the concept of dynamic pressure in fluid mechanics
Students of physics, engineers specializing in fluid dynamics, and anyone interested in gaining a deeper intuitive understanding of pressure changes in moving fluids.
Swamp Thing
Insights Author
I have read and understood the explanation of the Bernoulli principle based on conservation of energy, but what I would like is a more intuitive way of picturing just how the reduced pressure develops in, say, a venturi tube.
I want to be able to mentally track an element of the fluid and see, in my mind's eye, why a "slice" of the fluid flow presses on the walls with less and less pressure as it approaches the narrowest point. Is there an intuitive explanation of this sort?
Edit: I realized that I do not really understand it even in terms of conservation of energy. My problem is with dynamic energy : is it just the kinetic energy of an element?
A description that helps em intuitively grasp the principle is the idea of representing the force of the fluid against an object (like the walls of a Ventury tube) as "arrows of force". If the fluid is sitting still, like perhaps still air at sea level, then the full force of 14lbs/in.2 is applied to the wall of the tube. You could picture the arrows of force pointing directly at the wall.
If the air is moving, the arrows point at an angle. On an airplane wing, these arrows would point at the bottom of the wing at a certain angle (depending on the forward motion of the wing), but they point at a shallower angle, indicating that the air only strikes a "glancing blow" against that side. Striking at a shallower angle means it applies less pressure, just like getting grazed by a fastball won't knock you backwards, while a direct hit could break a bone.
  • · Replies 20 ·
  • · Replies 48 ·
  • · Replies 35 ·
  • · Replies 22 ·
9K
  • · Replies 23 ·
