When is a particle speeding up or slowing down?
  • Thread starter Thread starter Alain12345
    Particle
The discussion focuses on determining when a particle is speeding up or slowing down based on its position function s(t) = t³ - 9t² + 24t. The derived velocity function is v(t) = 3t² - 18t + 24, and the acceleration function is a(t) = 6t - 18. The particle is moving upwards when 0 < t < 2 and t > 4, while it is moving downwards between 2 < t < 4. The particle speeds up when both velocity and acceleration are either positive or negative, and slows down when they have opposite signs.
  • Understanding of calculus, specifically derivatives for velocity and acceleration
  • Familiarity with polynomial functions and their behavior
  • Knowledge of interval testing for determining function signs
  • Concept of motion in one dimension, particularly in relation to velocity and acceleration
  • Study the relationship between velocity and acceleration in motion analysis
  • Learn about interval testing for polynomial functions
  • Explore the concept of concavity and inflection points in calculus
  • Investigate real-world applications of motion equations in physics
Students studying calculus, physics enthusiasts, and anyone interested in understanding motion dynamics and the relationship between velocity and acceleration.
Alain12345
I need help with a question asking if the particle is speeding up or slowing down.
A particle moves on a vericle line. It's position, s, in metres at t seconds is given by s(t)= t^3-9t^2+24t
a) determine the velocity and acceleration functions
I got v(t)= 3t^2-18t+24 and a(t)= 6t-18
b) When is the particle moving up? Down?
I got when 0<t<2, t>4 and it's slowing down at 2<t<4
c) When is the particle speeding up? Slowing down?
I thought that I have to use a similar method to part b and make an interval chart, but I don't think I'm doing it right. I used the a(t) function and found the zero and used that in the chart.
Can someone help me out? Thanks.
It's speeding up whenever the acceleration and velocity are either both negative, or both positive. This is because then the acceleration and velocity are both in the same direction. When the acceleration is negative, and velocity positive, or vice versa, the particle is slowing down.
Also, in part b, you write it's slowing down for 2<t<4, when it should say "moving down". You might want to make sure you didn't write that down on your answer sheet too :p
