Parametric and Cartesian Equations
The discussion revolves around converting parametric equations to Cartesian form and vice versa, specifically focusing on the equations x = 4 cos(t) and y = 5 sin(t). Participants are exploring the relationships between the variables and the implications of trigonometric identities.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss solving for t in the parametric equations and substituting it into the other equation. There is also mention of using trigonometric identities to relate the equations. Some participants express confusion about the simplification process and the reverse conversion from Cartesian to parametric forms.
The discussion is active, with participants offering insights into the relationships between the parametric and Cartesian forms. Some guidance has been provided regarding the use of trigonometric identities and the geometric interpretation of inverse trigonometric functions. Multiple approaches to the problem are being explored, but no consensus has been reached.
Participants are navigating through potential gaps in understanding basic trigonometric concepts and the implications of the equations involved. There is a mention of homework constraints and the need to adhere to specific mathematical principles.
lemurs
ok I am give a parametric equations of
x= 4 cos t and y=5 sin t
I know that i have to solve the x equation for t then stick it in the y equation but i getting stuck or not rembering some simple stuff i should be.
I believe i get t= cos(inv) (x/4) and substiute it into t in y.
if so how so i simplify
5 sin(cos(inv)(x/4))
[tex]\frac{x}{4} = \cos t[/tex][tex]\frac{y}{5} = \sin t[/tex][tex]\sin^{2} t + \cos^{2}t = 1[/tex]
so then i would justs substiute in those in so it would be
x^2/16 +y^2/25
x^2/16 +y^2/25
Don't forget they equal one.
in general, sin(arcos(x)) can be solved by drawing a right triangle. arcos(x) is an angle theta whose cosine is x. So pick one of the angles that's not 90 degrees. Label that theta. Since theta is arcos(x), the adjacent side is x, and the hypotenuse is 1. So sin(theta) is opposite over hypotenuse. You can get the opposite side by pythagoras, and you're done.
ok i understnad that now but how would you do the reverse.. go form given a cartesian equation to a cause given X^2-y^2=1 how would you solve that
You're trying to make that into a parametric form? We know cosh2t - sinh2t = 1. so if you let x=cosht, and y=sinht, it works
In general, if you're completely at a loss, you can try to solve for y=f(x), let x=t, and y=f(t)
9K
  • · Replies 40 ·
