Solve X Equation for Sum of Forces in X/Y Direction
  • Thread starter Thread starter Rebel_Yell
    Explain
To solve for the sum of forces in the x and y directions, one must first identify all forces acting in each direction. The x components of these forces are determined using trigonometric functions, specifically cosine for the adjacent side of a right triangle. The net force in the x direction is calculated using the equation ΣFx = F1x + F2x + F3x + ..., where each F1x, F2x, etc., represents the x components of the individual forces. This method also applies to the y direction using the corresponding y components.
  • Understanding of vector components in physics
  • Knowledge of trigonometric functions (sine and cosine)
  • Familiarity with Newton's laws of motion
  • Ability to draw and interpret right triangles
  • Study the application of Newton's second law in two dimensions
  • Learn how to decompose vectors into components using trigonometry
  • Explore examples of force diagrams and free-body diagrams
  • Investigate the effects of frictional forces on net force calculations
Students in physics, engineers working on motion analysis, and anyone involved in mechanics or dynamics will benefit from this discussion.
Rebel_Yell
How do you set up equations for sum of forces in the x and y directions? I can do the y when it is only moving in the x direction, but I don't know how to set up the x equation.
Yes, of course, you can do the "y direction when it is only moving in the x direction" because that's trivial! I'm not sure what you really meant.
Normally one starts with "movement in a line" where we only have to worry about one direction. If something is moving on the x-axis with a force in the x-direction then vx= at+ v0 and x= (1/2)at2+ v0t+ x0.
Now you have motion in the plane (or 3 dimensions with x, y, z) so you have to separate everything into x, y, z components. If you are given "initial velocity" or "force vector" as length and direction, then you need to use trigonometry to decompose into x and y components. For example if the problem says "the initial speed is 20m/s at a direction 30 degrees above the x-axis, draw a picture showing a line at 30 degrees above the x-axis. Mark off a "length" of 20 on that line and draw a perependicular from that point to the x-axis. You see a right triangle with hypotenuse of length 20, "near side" along the x-axis (so its length is x), and "opposite side" parallel to the y-axis (so its length is y). Remembering that "sine" is defined as "opposite over hypotenus", sin(30)= y/20 or y= 20sin(30). Remembering that "cosine" is defined as "near side over hypotenuse", cos(30)= x/20 or x= 30 sin (30).
Once you have those components, you can just work with "x" and "y" separately- that's the nice thing about using components.
To solve for the sum of forces in the x direction, you will need to use the concept of vector components. This involves breaking down each force into its x and y components, and then adding them together to find the net force in the x direction.
To set up the x equation, you will first need to identify all the forces acting in the x direction. These forces could include applied forces, frictional forces, and any other forces acting in the x direction.
Next, you will need to determine the x component of each force. This can be done by using trigonometric functions such as cosine, which relates the adjacent side of a right triangle to the hypotenuse.
Once you have determined the x components of all the forces, you can add them together to find the net force in the x direction. This can be represented as:
Where ΣFx represents the sum of all the forces in the x direction, and F1x, F2x, F3x, etc. represent the x components of each individual force.
Using this equation, you can solve for the net force in the x direction and use it to determine the acceleration or motion of the object in that direction.
In summary, to set up equations for sum of forces in the x direction, you will need to identify all the forces acting in that direction, determine their x components, and then add them together to find the net force. This approach can also be used for the y direction, but with the y components of the forces instead.
  • · Replies 16 ·
