| Thread Closed |
Does the PA show that DM/DE is dynamically important in the outer solar system? |
Share Thread | Thread Tools |
| Nov1-06, 02:12 AM | #1 |
Reynaud and Jaekel's paper published in the Phsics ArXiv today:
Long range gravity tests and the Pioneer anomaly (Report-no: LPTENS 06/46) (Laboratoire de Physique The'orique de l'Ecole Normale Supe'rieure) |
| Nov1-06, 11:14 AM | #2 |
I was under the impression that dark matter and energy had already been ruled out as possible explanations of the Pioneer anomaly.
Given how little data we actually have on the matter, I doubt anyone is going to figure it out any time soon. Certainly not until we have more data to compare with. |
| Nov1-06, 11:30 AM | #3 |
I don't think you can rule anything out at this stage, certainly not 'DM' or 'DE' whatever they are.... As the paper in my OP puts it: |
| Nov1-06, 11:10 PM | #4 |
| Nov2-06, 01:20 AM | #5 |
http://www.arxiv.org/abs/gr-qc/0610160 I don't see how the subject heading of your post relates to this paper. The author makes reference to the "dark matter" and "dark energy" problems, but is talking only about modified gravity solutions to these problems. Dark matter and dark energy themselves don't enter into the analysis. |
| Nov2-06, 01:40 AM | #6 |
Edit: crossed post: Thank you ST, I have now corrected the broken link in the OP.
Nobody is drawing firm conclusions, that is why I phrased the thread title as a question. My point is, that after the drawing of a firm conclusion in another thread, now locked, that DM is not dynamically important in the solar system, a report is now published by Reynaud and Jaekel in which they raise the possibility of a link between the mysterious nature of DM/DE and the mysterious nature of the PA. I believe no firm conclusions can be drawn about either mystery but rather an open mind should be kept; the resolution of one mystery may also provide the solution to the other. I asked the question in the OP title in order to keep minds open. Do you not find the PA intriguing? Garth |
| Nov2-06, 10:05 AM | #7 |
| Nov2-06, 10:25 AM | #8 |
The problem as I see it being threefold, 1. If the gravitational field is being modified in some way this modification does not show up in the orbits of the outer planets, even though the PA manifested itself as soon as the spacecraft cleared Saturn and other noise 'quietened' down. 2. If DE is the cause then the acceleration might be expected outwards from the Sun, i.e. some form of 'anti-gravity' effect operating in the opposite direction to Newtonian gravity as DE is meant to. 3. DM could be the cause but only if inside, sunwards, of the Pioneers' orbits, in which case that too should show up in the Outer Planets' orbits. (Note that an effect was first looked for to test for a Planet X; the surprise was not only was a signal discovered but it was the same for both spacecraft on opposite sides of the Sun.) Garth |
| Nov2-06, 12:16 PM | #9 |
Note also:
1. The acceleration is aP = (8.74 ± 1.33) × 10−10 m/s2. 2. What is actually measured is a time acceleration of at = (2.92 ± 0.44) × 10−18 s/s2). 3. The effect has been constant and equal for both spacecraft from 10AU - 90AU. (Pioneer 10 - Feb 2003) (Other effects swamped it when they were closer than than 10AU from the Sun.) 4. That 'normal physics' from On-Board Systematics can so far explain a maximum of: i Radio Beam Reaction Force a = (1.10 ± 0.10) × 10−10 m/s2. . ii Anisotropic Heat Reflection a = (−0.55 ± 0.55) × 10−10 m/s2. . iii Differential Change of the RTG’s Radiant Emissivity a = 0.85 × 10−10 m/s2. . iv Constant Electrical Heat Radiation as the Source: not viable. v Helium Expulsion from the RTGs a = (0.15 ± 0.16) × 10−10 m/s2. . vi Propulsive Mass Expulsion a = ±0.56 × 10−10 m/s2. (source The Study of the Pioneer Anomaly: New Data and Objectives for New Investigation Turyshev et al.) This makes a maximum total of an = (2.1 ± 0.8) × 10−10 m/s2 that can be caused by normal physics leaving at least a minimum anomalous acceleration of ax = (6.6 ± 2.1) × 10−10 m/s2 to be explained. 5. Furthermore note the Hubble acceleration cH = 7.2 × 10−10 m/s2, which is consistent with this unexplained residual. The PA may therefore be cosmological and not local in nature, which would also explain why it does not show up in the closed orbits of the Outer Planets. Garth |
| Nov2-06, 01:17 PM | #10 |
I just think of this as one of those things to keep in mind as new theories of gravity come along. I won't be convinced there's a problem until we have a more reliable measurement.
| Nov2-06, 10:28 PM | #11 |
Garth, there is a very cute paper, published this year in Phys. Lett. B, that compares the supposed PA with Mercury's perihelion shift to demonstrate that the former is not due to DE.
After reading what peer reviewed papers are referenced on the wikipedia PA article, the scientific consensus seems very clear that the PA data is inconclusive (especially due to likely systematic errors), so we have no physical basis for discussion. Personally I'd love to see a better probe sent to investigate, but obviously someone needs to finance it. Otherwise, I understand outer planets are too slow to provide useful data, and if eccentric asteroids were easy to track precisely then I'm guessing someone would have done so about now. |
| Nov3-06, 01:31 AM | #12 |
I myself also do not believe that it is caused by DE, see my comment above, especially if DE is thought to be the cosmological constant as in your link paper. At present we have no firm idea about what DE actually is. However, the point I was making, and picked up from the OP paper, was that the two causes, one for the need for DE, and the other for the PA, could be related. My main point is for us not to be too confident that we have modelled gravitation correctly, and minds should be kept open. The question it leaves us is, "What then is the cause of the unexplained residual PA time drift?" Garth |
| Nov4-06, 12:01 PM | #13 |
Summing up:
1. The PA is measured as a residual blue doppler shift on signals returned back to Earth. The value of the frequency change is equal to: ad = (2.92 ± 0.44) × 10−18 s/s2). This can be interpreted as an acceleration (either towards the Sun or the Earth) equal to: aP = (8.74 ± 1.33) × 10−10 m/s2. 2. After possible on-board systematics forces are taken into account there is still a real minimum residual acceleration of: ax = (6.6 ± 2.1) × 10−10 m/s2 to be explained. 3. The anomalous acceleration is not dependent on range from the Sun. It appeared once the Pioneer spacecraft were gravity assisted by Saturn onto hyperbolic orbits. In any case before those encounters the effect would have been swamped by other effects, namely the solar radiation pressure and thruster gas leakage. 4. It does not show up in the orbital dynamics of the outer planets. This alone indicates to me that it cannot be modelled by modification in the gravitational field of the Sun. See Iorio's eprint Can the Pioneer anomaly be of gravitational origin? - answer: negative. Therefore, like ST, I also conclude that the answer to the OP question is negative, DM/DE is not dynamically important in the Outer Solar System. 5. However, there is either another unknown reaction force acting on the spacecraft, but every conceivable possibility has already been tried unsuccessfully, or the effect is actually a clock drift between atomic clock time and ephemeris time. 6. I conclude therefore that the PA is caused partly by conventional physics i.e. a reaction force acceleration equal to a maximum value of: ar = (2.1 ± 0.8) × 10−10 m/s2 and a clock drift or 'clock acceleration' of at least: at = (2.2 ± 0.7) × 10−18 s-1. I note that Hubble's constant in similar units (1/(Hubble Time) expressed in seconds) is equal to: H = (2.4 ± 0.2) × 10−18 s-1 (h=0.73) and where I have given H ±10% error bars. I find the consistency between at and H more than intriguing! A further conclusion is therefore that the PA is cosmological in origin and has been subsumed into the orbital dynamical model of the outer planets, which are on closed orbits. The effect only became observable when an accurate orbital determination was possible on spacecraft on open, hyperbolic, trajectories. Viable gravitational theories that predict such a clock drift should be given due consideration. Garth |
| Nov4-06, 01:39 PM | #14 |
If cosmological effects could be seen on the solar system scale, we would also have to see that the galaxy was expanding along with the rest of the universe, which is manifestly not the case.
| Nov4-06, 03:17 PM | #15 |
But, on the other hand Parlyne, what is your explanation of the PA? Garth |
| Nov5-06, 01:02 PM | #16 |
As I said before, we really don't even have enough data to conclusively demonstrate that there really is a Pioneer Anomoly (or at least one that isn't the result of some sort of systematic effect related only to the Pioneer probes themselves).
| Nov5-06, 02:53 PM | #17 |
Garth |
| Thread Closed |
| Tags |
| pioneer anomaly |
| Thread Tools | |
Similar Threads for: Does the PA show that DM/DE is dynamically important in the outer solar system?
| solar system | Introductory Physics Homework | 1 | ||
| Show that the system is linear? | Calculus & Beyond Homework | 1 | ||
| How would the solar system capture an extra solar planet ?? | General Astronomy | 14 | ||
| Our solar system | General Astronomy | 8 | ||
| The Solar System | General Astronomy | 2 | ||
