Thread Closed
identical particles
Share Thread Thread Tools
Nov1-06, 02:02 PM   #1
identical particles
When discussing identical particles, it is said that a wave function must be either symmetric or antisymmetric wrt exchange of particles. Could we not have, in general,
[tex] \psi(r_1,r_2)=e^{i\phi}\psi(r_2,r_1)[/tex]
since the overall factor is physically meaningless?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> A quantum simulator for magnetic materials
>> Atomic-scale investigations solve key puzzle of LED efficiency
>> Error sought & found: State-of-the-art measurement technique optimised
Nov1-06, 07:18 PM   #2
Is this like bosons, fermions and anyons?
Nov1-06, 08:36 PM   #3
I've never heard of an anyon. I found a brief section on it on wiki. Can you provide any details?
Nov1-06, 09:45 PM   #4
identical particles
The symmetry or antisymmetry drops out of field theory in three dimensions. If you restrict yourself to two dimensions, you no longer have a strict exclusion principle, and flipping the two particles yields whatever phase you want with respect to the original state vector. These are anyons.
Nov1-06, 10:40 PM   #5
Let the operator for swapping the particles be [itex]\hat{S}[/itex] in the position representation. Now apply it twice to our wavefunction:
[tex]
\begin{array}{cll}
\hat{S}^2\psi(r_1,r_2) = \hat{S}\psi(r_2,r_1)=\psi(r_1,r_2) &\Rightarrow \hat{S}^2 = 1 \\
&\Rightarrow \hat{S} = \pm 1 \\
&\Rightarrow \psi(r_1,r_2)=\pm\psi(r_2,r_1)
\end{array}
[/tex]
Nov1-06, 11:27 PM   #6
[tex] S^2 =1[/tex] does not imply [tex] S=\pm 1[/tex]. All this implies is [tex] S=S^{-1}[/tex].
And I believe you just proved that all states are either symmetric or antisymmetric. What about the state |0>|1> ?
In fact, S must have some zero's on the diagonal in the position basis:
[tex] <x,y|S|x,y>=<x,y|y,x> = \delta_{xy}[/tex]
Am I mistaken?
Nov2-06, 08:45 AM   #7
Can you think of an example where
[tex]\hat{S}^2 = 1 \mbox { but } \hat{S} \ne \pm 1[/tex]
Nov2-06, 08:47 AM   #8
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Quote by masudr
[tex]e^{i\frac{\pi}{4}}[/tex]?
Nov2-06, 08:50 AM   #9
Quote by Euclid
And do you mean
[tex]
\langle x_1',x_2' | \hat{S} | x_1,x_2 \rangle =
\langle x_1',x_2' | x_2,x_1 \rangle =
\delta_{x_1'x_2,x_2'x_1}
[/tex]
Nov2-06, 08:55 AM   #10
Quote by selfAdjoint
[tex]\hat{S}=e^{i\frac{\pi}{4}} \Rightarrow \hat{S}^2 = e^{i\frac{\pi}{2}} = i \ne 1[/tex]
Nov2-06, 09:02 AM   #11
Recognitions:
Homework Helper Homework Help
You can conclude from S^2=I (and that S is Hermitian) that the eigenvalues are [itex]\pm 1[/itex] (take the Pauli spin operators for example). If the particles are identical, then H must treat them on equal footing. It just means that [H,S]=0, so you can find a complete set of eigenstates common to H which are either symmetric or antisymmetric.
Nov2-06, 09:45 AM   #12
Quote by masudr
Yes, a diagonal matrix with 1 and -1's on the diagonal.
Nov2-06, 09:52 AM   #13
Quote by Galileo
Where do anyons come into all this? What you say here shows that all particles can be thought as a superposition of fermionic and bosonic states.
Also, why would we expect S to be hermitian?
Nov2-06, 11:38 AM   #14
Recognitions:
Quote by Euclid
They don't, since that wasn't my intention.
You can prove S is Hermitian quite easily.
I don't think you can prove the wavefunction must be (anti)-symmetric from QM. The fact that the states are required to be either completely symmetric or antisymmetric under the exchange of two identical particles is a postulate.
Nov2-06, 12:22 PM   #15
Quote by Galileo
Is that true?
I know that if you derive the (relativistic) Dirac equation the Pauli spin matrices fall right out. So I can see how the antisymmetric nature comes about for fermions. As for bosons...i have no idea.
Nov2-06, 12:39 PM   #16
Quote by Euclid
Because S commutes with respect to the Hamiltonian, and since the wavefuction is an eigenfunction of H it will be an eigenfunction of S also - the eigenvalue being the (experimentally measurable) spin. Whichever way to want to look at it, S must be hermitian.
proof:
If H is hermitian then:
[tex]H^\dagger = H[/tex]
and if S and H commute:
[tex][H,S] = 0[/tex]
[tex]HS - SH = 0[/tex]
[tex]HS = SH[/tex]
[tex](HS)^\dagger = (SH)^\dagger[/tex]
[tex]S^\dagger H^\dagger = H^\dagger S^\dagger[/tex]
[tex]S^\dagger H = H S^\dagger[/tex]
but since [H,S] = [S,H] = 0 then SH=HS and so it must be true that
[tex]S^\dagger = S[/tex]
and so S must be hermitian
Nov2-06, 01:35 PM   #17
First: Requierment that permuting particles leaves physical state intact leads to conclusion that representation of permutational grouop must act as multiplication with [tex]e^{i\phi}[/tex]. Even, if you take that in form of some general unitary operator you will finally end with reducible operator whose irreducible subspaces are 1D, and hence his action is reduced to simple scalar multiplication by phase factor. Then, application of same permutation again must be identical operator, thus giving only two possible 1D representations, +1 and -1.
Second: take a system which is in state [tex]|\phi>=|s>+|a>[/tex], where [tex]|s>[/tex] is from symmetric subspace of permutational group representation and [tex]|a>[/tex] is from antisymmetric part. Attack this state with some permutation and you will have [tex]D(S)|\phi>=|s>-|a>[/tex], which is not colinear with original state, and this is not allowed by assumption of identical particles. Thus all systems must be in either symmetric or antisymmetric state.
Thread Closed
Thread Tools
Similar Threads for: identical particles
Thread Forum Replies
identical particles Advanced Physics Homework 1
Identical particles Advanced Physics Homework 9
QM - Identical Particles, and energy states Advanced Physics Homework 6
Two identical non-interacting particles Advanced Physics Homework 1
are all particles identical? High Energy, Nuclear, Particle Physics 3
