What Caused the Heat in the Big Bang?
  • Context: Graduate
  • Thread starter Thread starter chosenone
    Heat
The discussion revolves around the origins of heat in the Big Bang, exploring various hypotheses related to singularities, energy density, and the nature of spacetime. Participants propose different models and ideas, including connections to black holes, string theory, and the implications of energy density in the universe.
  • Some participants suggest that the heat from the Big Bang could be attributed to the universe being a singularity of a black hole, where the collapse of a star creates a sphere of warped spacetime that eventually decompresses and explodes.
  • Others advocate for string theory, proposing that the compression of "strings" into a small space leads to an explosive release of energy as they separate.
  • One participant presents a model where gravity compresses matter into a point, resulting in a large particle that grows as more energy is forced into it, suggesting that we exist in a concentrated energy bubble rather than solid matter.
  • Another idea posits that extreme gravitational forces could tear a hole in spacetime, pulling an anomaly of expanding nothingness outward, converting matter into energy in the process.
  • There is a discussion about the concept of negative energy density in a perfect vacuum and its implications for energy density in singularities.
  • Some participants argue that singularities should have infinite energy density, while others challenge this notion, suggesting that singularities are not infinite mass with infinite energy.
  • One participant questions the logic of infinite density in the context of an expanding universe, suggesting that the laws of physics may not support the existence of infinite density after the universe's formation.
Participants express multiple competing views regarding the nature of singularities, energy density, and the implications for the Big Bang. There is no consensus on the correct model or explanation for the heat in the Big Bang.
Discussions include unresolved assumptions about energy density, the nature of singularities, and the implications of gravitational forces on the universe's expansion and collapse. Participants do not reach a definitive conclusion on these topics.
chosenone
The only thing I could think of that could create the heat caused in the big bang,is that if the universe is a singularity of a black hole.when the star was collapsing into one.a sphere of spacetime warped around the infinitely compressed matter by gravity when matter could'nt be forced into one point anymore,and the heat of the matter at the heart of the sun plus the heat of spacetime too,was inside the sphere of spacetime when it folded over the matter.then on the inside the matter then decompressed and exploded into the matter that started the universe.so the back ground radiation is from this.sound good to you?
Astronomy news on Phys.org
Well, string theory (of which I am a strong advocate) has another suggestion. It postulates that since all of these "strings" were compressed into such a small space, their energies compounded, and thus, they "exploded" apart from each other.
well if you don't like my uncompressing theory how about my other one.when gravity at the center of the star collapsing compresses matter into a point,and since matter is just focused energy in spacetime,the matter forces its energy into one point not solid matter,so there's not limit to how much energy can be in one spot not matter.so when the energy is forced into one spot like this it just creates a big particle that just gets bigger as more energy is forced into it.and let let edge of the universe be folded spacetime and we walk around in a concentrated energy bubble not solid matter.or how about my favorite one.when gravity a the center of the star becomes to great it tears a hole in the fabric of spacetime a pulls a anomaly of expanding nothing outward from the point it teared.and before the universe tears itself apart,the matter of the sun hits the edge of the expanding nothing and is converted into energy and is aborb inside sealing to anomaly forever and still creating a universe.
I think your idea definitely has merit. You should probably post in the "Theory Developement" Forum, and get the appropriate criticism (good and bad).
chosenone: When you said there is a limit to energy density, it gave me an idea. A singularity can only get to 0 energy density. But why not otherwise? What about negative energy? In a "perfect" vacuum, where there is no positve energy, but there is negative energy. So can this be applied to energy density?(i'm sure I've heard of negative energy density.)
Singularities ought to have infinite energy density, no?
Eh: yup.
one would assume that since you can measure the energy level of a singularity to know how much energy it has,by either using its gravitational field ,to reverse it by using e=mc^2,by saying energy is to mass as gravity is to mass,then by knowing the gravity field strength a a singularity you know how much matter in the star there was before it collapsed into one,the you also know how much energy there was in every atom that was converted into energy as it was aborbed into the singularity,you wopuld know that a singularity is'nt infinite mass,with infinite energy!
To make the universe smaller, increases the mass density. Hence, if you try to crush the size of the universe into an infinitely small volume, you're going to get infinite density.
philosophical debates and the reality are two different things,if the universe is expanding that tells you that infinite density on the other side is doesn't exist as a law of physics.it just sound good.but if the universe is a singularity expanding,maybe when if formed its possible to say that but not after.its going from infinite density to infinite nothing,but well still be here,unless you think it will expand till it pops rather than collapse,but if its going to expand then collapse what kind of force can force infinite mass,with infinite gravity to expand instead of staying a small point indefinately??and then collapse on itself again,does'nt make sense!
  • · Replies 28 ·
  • · Replies 20 ·
  • · Replies 25 ·
  • · Replies 32 ·
  • · Replies 26 ·
