Thread Closed
How to produce fast Neutrons
Share Thread Thread Tools
Nov4-06, 03:19 PM   #1
Hi,
I'd like to find out, how i can produce fast Neutrons >1 MeV at least, but
>20 MeV would be great.
I found out, that using Deuterium+Tritium would be one possibility, but
Tritium is not easy to get and requires great care. I can Accelerate Ions
to up to 25 MeV with a 'Tandem'-Accelerator.
Any Ideas?
Thx,
Thomas
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Nov4-06, 03:19 PM   #2
Electrostatic D-T fusion is probably the easiest way. If you can't get
ahold of tritium, you are likely to have trouble getting other things.
If D-D fusion is high-energy enough, you can get plenty of neutrons
from that too. Fusion product energies are on wikipedia. You are kind
of vague, though. What is the application? What is your situation?
Nov4-06, 03:19 PM   #3
Thomas Mueller wrote:
> Hi,
> Any Ideas?
http://www.aip.org/tip/INPHFA/vol-9/iss-6/p22.html
http://www.sciner.com/Neutron/neutron_radiography.htm
http://www.lbl.gov/Tech-Transfer/techs/lbnl1764.html
"Neutron generators like these can significantly enhance homeland
security."
<http://www.ncbi.nlm.nih.gov/entrez/query.fcgi?cmd=Retrieve&db=PubMed&list_uids=9022213&dopt=Abstract>
Uncle Al
http://www.mazepath.com/uncleal/
(Toxic URL! Unsafe for children and most mammals)
http://www.mazepath.com/uncleal/qz.pdf
Nov4-06, 03:19 PM   #4
Ok thanks to you and Uncle Al... It seems that i already found all the
possibilites to produce neutrons, and there arent any other reactions i
can use. Im a student starting to write my diploma thesis, and i want to
examine how a myon-detector for the Atlas-Expriment behaves in fast
neutron background.
I'll try to simulate D-T Reaction with Geant4, if its the best way to
produce fast Neutrons i guess i can organize some Tritium...
Thomas
Nov4-06, 03:19 PM   #5
Thomas Mueller <Thomas.Andreas.Mueller@elfstone.de> wrote:
> Hi,
> Any Ideas?
> Thx,
> Thomas
Hi Thomas,
7Li(p,n) is also a possibility. I'm pretty sure that the cross-section is
lower than for T(d,n) or T(p,n), but I suspect that it will still provide
more than enough neutrons for your needs. It's easier to get and handle
than tritium, and the 7Be left in the target can be counted with a gamma
ray detector afterwards to know how many neutrons were produced.
Note that all these reactions produce gamma rays >18MeV, so there is
likely to be a lot of background in your tests.
Cheers,
Rob Komar
Thread Closed
Thread Tools
Similar Threads for: How to produce fast Neutrons
Thread Forum Replies
Lightspeed fast, then slowed, then fast again. General Physics 3
What's happening to our produce? General Discussion 18
how light produce?? and why we can see it? General Physics 10
accelerating neutrons, production of ultracold neutrons High Energy, Nuclear, Particle Physics 8
A possible way to produce thrust from ZPE? General Physics 6
