How to Calculate Total Force on a Charge at the Center of Curvature?
  • Thread starter Thread starter mateoguapo327
    Electromagnetism
The problem involves calculating the total force on a charge located at the center of curvature of a semicircular line of charge. The semicircle has a radius of 60.0 cm and a charge distribution described by a cosine function. The total charge on the semicircle is given as 12.0 microcoulombs, and the charge at the center is 3.00 microcoulombs.
  • The original poster attempts to calculate the total force by considering the electric field contributions from small segments of the semicircle. They express the need for help in understanding their approach and the discrepancies between their result and the book's answer.
Some participants have provided guidance on calculating the electric field at the center of the semicircle and suggested integrating the contributions from the charge distribution. There is an acknowledgment of differing results, and the original poster is encouraged to show their work in future posts.
The original poster's calculation resulted in a force of -0.526 N, while the book states the answer is -0.707 N. There is a mention of needing to solve for the charge per unit length, which may be a point of confusion.
mateoguapo327
help! I need help with this homework problem.
--A line of positive charge is formed into a semicircle of radius R=60.0 cm. The charge per unit length along the semicircle is described by the expression [lamb]= [lamb]naught cos [the] . The total charge on the semicircle is 12.0 microcoulombs. Calculate the total force on a charge 3.00 microcoulombs at the center of curvature.--
The figure shows the semicircle with is center at the origin going from 0 to pi. [the] is the angle formed by dragging R clockwise from the positive y axis.
the answer in the book is -0.707Nj and I got -0.526N. Can someone please help me figure out how to properly go about solving this problem?
consider the electric field at the center of the semicircle due to a little piece of the semicircle at angle θ. by symmetry, only the vertical component of this field contributes:
dEy = - 1/4πε0 cos θ dq/r2 = - 1/4πε0 cos θ λrdθ/r2 = - 1/4πε0 cos2 θλ0dθ/r
then integrate from π/2 to -&pi/2:
Ey = -λ0/4πε0r∫cos2 θ dθ = -λ0/8ε0r
the force on the charge is the Fy = qEy
we also need to solve for λ0.
Q = ∫dq = ∫λ0rcos θ dθ = 2rλ0
λ0 = Q/2r
finally
Fy = -qQ/16ε0r2
plug in the numbers and you get -0.70588 N.
Ahem!
Mateoguapo:
https://www.physicsforums.com/showthread.php?s=&threadid=28
In the future, please show your work first.
Thanks,
oops. my bad.
  • · Replies 19 ·
23K
9K
  • · Replies 17 ·
35K
