Why do galaxy clusters form sheets?
  • Context: Graduate
  • Thread starter Thread starter drag
    Clusters Galaxy
The discussion centers on the formation of galaxy clusters into sheets, exploring potential explanations and theories related to their structure. Participants examine various factors, including gravitational interactions, angular momentum, and early cosmic conditions, while considering both theoretical and observational aspects.
  • One participant suggests that the existence of galactic cluster sheets may be due to kinematic solutions for bodies initially spread out and influenced by gravitational forces.
  • Another proposes that early galactic collisions could have redistributed angular momentum, contributing to the formation of these sheets.
  • A different viewpoint mentions that sheets may have evolved from clouds of preferred spin, although this idea is noted as speculative.
  • Concerns are raised about whether expansion would prevent shockwaves from influencing the formation of sheets.
  • One participant questions the nature of chaotic behavior in these structures and seeks mathematical models that might explain the observed phenomena.
  • Links to external resources are shared, indicating a belief that the sheets are not well-defined and that further exploration is needed.
Participants express multiple competing views regarding the mechanisms behind the formation of galaxy cluster sheets. There is no consensus on a single explanation, and various hypotheses are presented and debated.
Some participants note the complexity of the topic, mentioning unresolved aspects such as the role of angular momentum and the nature of chaotic behavior in the formation of sheets. The discussion reflects a range of assumptions and conditions that are not fully explored.
drag
Greetings !
I just read Saint's post in the "moving galaxy"
thread and though I knew the answer to that, I do
not believe I have so far read somewhere an
explanation for the existence of the galactic
cluster sheets.
So, is there a known and recognized reason ?
(My guesses :
1. The same reason that star-systems and galaxies are
mostly two-dimensional - a simple kinematic
solution for a system of bodies enitially spread
around mostly at rest and mutually affected by
2. Some form of quantization during the BB ? )
Thanks.
"I sometimes ask myself how it came about that
I was the one to develop the theory of relativity.
The reason, I think, is that a normal adult
never stops to think about problems of space and time.
These are things which he has thought about as a child.
But my intellectual development was retarded, as a
result of which I began to wonder about space and time
only when I had already grown up."
Albert Einstein
Live long and prosper.
Astronomy news on Phys.org
drag-
How about early galactic collisions and their spatial redistribution of angular momentum?
Also, sheet clusters may have evolved from clouds of preferred spin.
Your guesses are good ones, too!
Greetings Loren !
You mean - shockwaves ?
Wouldn't expansion prevent that ?
What do you mean (matter & anti-matter)?
Thanks, but my first one does not explain why
the sheets are mostly parallel at all.
And my second is far from anything I could provide
an educated opinion about - just a wild thought.
drag-
Collisions between galaxies of various orientations in the early universe may have enabled parallel distribution. Preferring low angular velocity, the developing galaxies expanded in one plane while conserving angular momentum and increasing entropy.
Before galaxies there were stars, and before them, hydrogen molecules. In a given primordial region much larger than a galaxy but much smaller than the universe there would have been probably an overall angular momentum which condensed eventually into local galactic sheets.
Greetings !
Intresting.
Is this some type of Chaotic behaviour (there are
huge amounts of stars and matter in every "sheet") ?
Are there some mathematical models that address
such a solution ? What's the difference if we
consider every star to be a galaxy and then
use the same model ? Do the "sheets" have angular
momentum (which could "help" such a model) ?
(Links would also be appreciated people, I'm going
to look for some myself too.)
Thanks !
  • · Replies 0 ·
