| Thread Closed |
quantum analogue of classical mechanics |
Share Thread | Thread Tools |
| Nov4-06, 03:28 PM | #1 |
My question involves a comparison between classical and quantum
mechanics. In classical mechanics of solid bodies there are two schemes; call them D(iscrete) and C(ontinuous). In D one studies systems of points - point masses and their movement under the influence of gravity and more general Newtonian attraction. We write down the equations of motion for such discrete systems. Now in scheme C we don't repeat the analysis in D for infinitely many points. Briefly, one does not repeat for a continuum of points the analysis used for D: the sums in D are replaced by integrals in C. In quantum mechanics we know the analogue of D: essentially Schrodinger's equation for one particle or for a finite number of particles. My question is, what is a the QM analogue of (C) ? Also, how can one apply quantum mechanics without having some idea of an answer to this question ? Hope this makes sense, Thanks, David. -- Posted via Mailgate.ORG Server - http://www.Mailgate.ORG |
| Nov4-06, 03:28 PM | #2 |
David Macmanus wrote:
> My question involves a comparison between classical and quantum > mechanics. In classical mechanics of solid bodies there are two schemes; > call them D(iscrete) and C(ontinuous). In D one studies systems of > points - point masses and their movement under the influence of gravity > and more general Newtonian attraction. We write down the equations of > motion for such discrete systems. > > Now in scheme C we don't repeat the analysis in D for infinitely many > points. Briefly, one does not repeat for a continuum of points the > analysis used for D: the sums in D are replaced by integrals in C. > > In quantum mechanics we know the analogue of D: essentially > Schrodinger's equation for one particle or for a finite number of > particles. > > My question is, what is a the QM analogue of (C) ? Quantum field theory. Arnold Neumaier |
| Nov4-06, 03:28 PM | #3 |
> My question is, what is a the QM analogue of (C) ? If your continuous medium can be represented as a field, and an effective Lagrangian that simulates its classical behaviour be written for it, you could order a quantum theory for the field. The classical trajectory of the field being one that minimizes its Lagrangian, its quantum 'trajectory' may be written down by summing over all possible field trajectories with (complex) weights directly proportional to the amplitude of each trajectory. The amplitude of each trajectory is ~ exp(i*S) where S = integral over relevant time and space of the Lagrangian. If you are thinking of quantum versions of incompressible fluid flow etc, I bet they could be modelled by some sophisticated self-interacting quantum field theory or the like. Hope this helps, or opens up further discussion. -Souvik |
| Nov4-06, 03:28 PM | #4 |
> My question involves a comparison between classical and quantum > mechanics. In classical mechanics of solid bodies there are two schemes; > call them D(iscrete) and C(ontinuous). [...] My question is, what is a the QM > analogue of (C) ? Hilbert spaces, the same as in Quantum Mechanics. Let P be the classical phase space, P_0 any countable dense subset, and let H_P the Hilbert space generated by P_0 (i.e., as the closure of the complex vector space that is freely generated from P_0 as an orthonormal basis). For each p in P_0, the corresponding state is |p>. A classical observable is then defined as a bounded linear operator, A, over H_P such that A commutes with all the projections |p><p|: A |p><p| = |p><p| A, for all p in P_0. This is a quantum theory with supersection. The subspaces C |p> (for each p in P_0) give you the superselection sectors. Since each sector is 1-dimensional, there is no (meaningful) coherent superpositions. Let B_P be the corresponding algebra of operators. Then the state space associated with B_P is just P, itself. The algebra B_P is just the algebra of classical observables over P. (A state is defined formally as a linear functional W over the operator algebra with W[o] giving you the "expectation" of operator o, such that W[a] >= 0 if a >= 0; and W[1] = 1). Each quantum degree of freedom has a dynamics given by the Heisenberg equation. As Hojman and Shepley (1990) showed, such dynamics must always have a classical Hamiltonian dynamics in the limit as h-bar -> 0 ... meaning it's a quantization of a Hamiltonian dynamics. However, the degrees of freedom corresponding to superselection parameters need not be so constrained and may be governed by any type of law of motion, Lagrangian/Hamiltonian/or otherwise. Since the system above has only superselection degrees of freedom, there is no necessity of any Hamiltonians appearing anywhere. Going the other way, starting out with a classical phase space P, a quantum theory (which has non-trivial coherent sectors) comes about by smearing the states |p> of P_0 so that <p|q> != 0 is allowed for p != q. This is an instance of Berezin quantization and yields an equivalent foundation for quantum theory. The general states in the Berezin phase space are positive-definite and may be interpreted as probability densities. The space is effectively related to the Wigner "phase space" (which does not have positive-definite distributions for its states) by a Gaussian smear. Since the basis P_0 is not orthonormal, then it's no longer possible to exactly produce the identity operator I = sum (|p><p|: p in P_0), as you could in the classical case. The closest approximation to the identity operator is directly related to the "reproducing kernel" and underlies the smearing mentioned twice above. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: quantum analogue of classical mechanics
| Fundamental difference between classical and quantum mechanics | Introductory Physics Homework | 2 | ||
| quantum analogue of classical mechanics | General Physics | 3 | ||
| Quantum mechanics and classical physics | Quantum Physics | 13 | ||
| Classical vs Quantum Mechanics | General Physics | 1 | ||
| classical and quantum mechanics | General Physics | 6 | ||
