| Thread Closed |
Scene -> Optical Image; under relativistic conditions ? |
Share Thread | Thread Tools |
| Nov4-06, 03:39 PM | #1 |
In [1] Berthold K.P. Horn argues against linear methods for stereoscopic image
registration in machine vision. Horn explains that - "Methods based on projective geometry yield a transformation matrix T that in general does not correspond to a physical imaging situation -- [the latter amounting to the product of] a rotation, a translation and a perspective projection". - "The [general] transformations of projective geometry correspond [instead] to taking a perspective image of a perspective image [of an scene, what doesn't occur in an eye or a camera]". Now of course the physical imaging situations Horn talks about are non-relativistic. My question is : does special relativity by any chance repair the situation, in the sense that -relativistic- imaging situations would in general relate the geometry of a scene to that of its image as would (while neglecting relativistic effects) taking a perspective image of a perspective image of the same ? The motivation of that question is that I believe presenting SR as an "extended theory of perspective" would help people understand what it is about. And the above fact - if true - would help justify such as name for it. TIA, Boris Borcic -- [1] B. K. P. Horn. Projective Geometry Considered Harmful. http://www.google.com/search?q=Projective+Harmful , 1999 |
| Nov4-06, 03:39 PM | #2 |
Boris Borcic wrote:
> In [1] Berthold K.P. Horn argues against linear methods for > stereoscopic image registration in machine vision. Horn explains that > > - "Methods based on projective geometry yield a transformation matrix > T that in general does not correspond to a physical imaging situation > -- [the latter amounting to the product of] a rotation, a translation > and a perspective projection". > > - "The [general] transformations of projective geometry correspond > [instead] to taking a perspective image of a perspective image [of an > scene, what doesn't occur in an eye or a camera]". > > Now of course the physical imaging situations Horn talks about are > non-relativistic. My question is : does special relativity by any > chance repair the situation, in the sense that -relativistic- imaging > situations would in general relate the geometry of a scene to that of > its image as would (while neglecting relativistic effects) taking a > perspective image of a perspective image of the same ? Your question seems to presuppose a certain familiarity with terminology used in the field of "steroscopic image registration". I find it hard to decipher what precisely terms like "physical imaging situation" refer to. I can presume that images are captured by registring light rays emanating from an object and passing through a lense or a pinhole on, say, a photographic plate or a film. This is a non-linear mapping from the points of the object to the points on the photographic plate, whose details depend on the geometry of the camera. Based on this simple consideration, it is doubtful that such a mapping would suddenly become linear if special relativity is taken into account. In fact, for small object and camera velocities, should should be only negligible differences the relativistic and non-relativistic versions of this mapping, the latter of which is already known to be non-linear. For more detailed arguments, you have to tell us more precisely what you mean by "physical imaging situation" and "perspective" in your question. > The motivation of that question is that I believe presenting SR as an > "extended theory of perspective" would help people understand what it > is about. And the above fact - if true - would help justify such as > name for it. Even if that were true (which appears doubtful), the number of people who are well familiar with the "regular" theory of perspective before attepmting to study special relativity is not likely to be very large. However, that's just a guess. You may be better informed on this point. Igor |
| Nov4-06, 03:39 PM | #3 |
On Fri, 29 Sep 2006, Boris Borcic wrote:
> My question is : does special relativity by any chance repair the > situation, in the sense that -relativistic- imaging situations would in > general relate the geometry of a scene to that of its image as would > (while neglecting relativistic effects) taking a perspective image of a > perspective image of the same ? about. And the above fact - if true - > would help justify such as name for it. I don't think I understand your robot vision terminology, but you might or might not find it useful to know that the effect of Lorentz transformations of the celestial sphere for an arbitrarily moving observer in Minkowski vacuum is given by the action of the Moebius group on the Riemann sphere: http://math.ucr.edu/home/baez/physic...R/penrose.html http://math.ucr.edu/home/baez/physic...spaceship.html So, there's certainly a link with -conformal- geometry on the sphere. On the surface, you are talking about something different (relavistic view camera?), but the above should help you get started. "T. Essel" |
| Nov4-06, 03:39 PM | #4 |
Igor Khavkine wrote:
> Boris Borcic wrote: >> In [1] Berthold K.P. Horn argues against linear methods for >> stereoscopic image registration in machine vision. Horn explains that >> >> - "Methods based on projective geometry yield a transformation matrix >> T that in general does not correspond to a physical imaging situation >> -- [the latter amounting to the product of] a rotation, a translation >> and a perspective projection". >> >> - "The [general] transformations of projective geometry correspond >> [instead] to taking a perspective image of a perspective image [of an >> scene, what doesn't occur in an eye or a camera]". >> >> Now of course the physical imaging situations Horn talks about are >> non-relativistic. My question is : does special relativity by any >> chance repair the situation, in the sense that -relativistic- imaging >> situations would in general relate the geometry of a scene to that of >> its image as would (while neglecting relativistic effects) taking a >> perspective image of a perspective image of the same ? > > Your question seems to presuppose a certain familiarity with > terminology used in the field of "steroscopic image registration". I > find it hard to decipher what precisely terms like "physical imaging > situation" refer to. I can presume that images are captured by > registring light rays emanating from an object and passing through a > lense or a pinhole on, say, a photographic plate or a film. I am no expert on machine vision, just informing myself; the first sentence on the topic of Horn's article I offered as background, but as it wasn't my concern maybe I went too fast. Allow me to be more precise by citing a paragraph of Horn's introduction : <quote> We revisit this topic here in the context of a simpler problem, that of exterior orientation with respect to a planar object. We examine the difference between the mapping from the object plane to the image plane defined by true perspective projection and that defined by projective geometry. We show that virtually none of the transformations allowed by projective geometry correspond to real camera image-taking situations. We then compare the algorithms and study the sensitivity to noise using Monte Carlo methods and show that the error sensitivity of projective geometry based methods is much higher. <unquote> Note that he does *not* say that transforms that *do* correspond to "real camera image-taking situation" *fail* to be allowed by projective geometry. > This is a > non-linear mapping from the points of the object to the points on the > photographic plate, This is not what Horn says. What he says/shows is that under an adequate choice of representation/coordinate system : <quote> We can always find a matrix T corresponding to a real perspective projection (if we assume that the principal point is known), using the equations above, but in general it is not possible to go in the other direction, that is, to find a perspective projection that corresponds to an arbitrary matrix T . That is, almost all homogeneous transformations T have the property that they do not allow a physical interpretation in terms of rigid body motion and perspective projection. </unquote> Should I reproduce the derivations ? > whose details depend on the geometry of the camera. Based on this simple > consideration, it is doubtful that such a mapping would suddenly become linear > if special relativity is taken into account. Again, what Horn says isn't that the transform fails to be linear, it is that the whole linear group of transforms under consideration is too large. What I am asking is whether it stays too large when special relativity is admitted to play a role. And of course this question involves unknowns, since stepping up to SR implies relative motions and getting more precise about shutters and how the image forms in space-time. So I guess my question should be qualified with "assuming the most natural hypotheses about shutters". >> The motivation of that question is that I believe presenting SR as an >> "extended theory of perspective" would help people understand what it >> is about. And the above fact - if true - would help justify such as >> name for it. > > Even if that were true (which appears doubtful), the number of people > who are well familiar with the "regular" theory of perspective before > attepmting to study special relativity is not likely to be very large. My point is that "all is perspective" would be much superior to "all is relative" to speak of what SR says. I can still remember the "aha !" when I realised at age 4 that distance from any object conditioned its optical apparence, and I find it hard to imagine anybody endowed with vision who'd fail to possess that degree of intimate familiarity with the rules of perspective, what's largely sufficient for the purpose. Regards, Boris Borcic -- "La toute-puissance appartient-elle au pair d'yeux ?" |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Scene -> Optical Image; under relativistic conditions ?
| What's the difference between initial conditions and boundary conditions? | Differential Equations | 9 | ||
| How to capture live video/image using Matlab without Image acq toolbox | Math & Science Software | 1 | ||
| Analysis - proof involving 1-1, image and pre image of sets | Calculus & Beyond Homework | 4 | ||
| reason for optical activity(of optical isomers) | Chemistry | 1 | ||
| Convert a text file into an image (or generate an image with fortran) | Computing & Technology | 1 | ||
