IKu
- 9
does anyone know where i can find a frequency to voltage converter or know how to make one? preferably using a low voltage supply... thanks!
The discussion revolves around designing a frequency to voltage converter, particularly for converting tachometer signals from a car into an analog voltage signal. Participants explore various components, circuit designs, and specifications, while addressing the challenges faced by those new to the topic.
Participants express varying levels of understanding and experience with the topic, leading to some confusion and multiple interpretations of circuit design and component functions. No consensus is reached on the specifications or effectiveness of the proposed designs.
Participants mention specific component values and configurations, but there are unresolved assumptions regarding the circuit's performance and the accuracy of calculations. The discussion includes potential dependencies on definitions and the need for further clarification on technical terms.
This discussion may be useful for individuals interested in electronics, particularly those looking to design or understand frequency to voltage converters, as well as those working on automotive data logging projects.
Frequency to voltage? I'm not sure I understand what you are trying to do - they are unrelated to each other.Originally posted by IKu
Use the LM324 quad op amp. With two of the amps, some resistors, a npn transistor, and a capacitor, you can make a good Voltage Controlled Osicllator( w/ triangular and square wave outputs). The chip can use a wide supply voltage; 3 to 30 vdc.does anyone know where i can find a frequency to voltage converter or know how to make one? preferably using a low voltage supply... thanks!
Since the output is 66rpm per volt, at full scale (12 volt output), your input would be 792rpm. I bet you engine will turn more than this? The way I see the circuit, if you change the 100kohm resistor to 10kohm, the full scale output would be about 10 time grater (7920rpm).they have example diagrams using this piece:
https://netfiles.uiuc.edu/ericlin/www/ftov.jpg
would this work?
No, I'm the one screwed up. You're right. 66Hz=3960cycles(rpm)/min so at 2volt you would have 7920rpm.i think the output is 66Hz/volt, so multiplying that by 60 would give me rev/min, right? so even at 2 volt output, i would be at like 8000 rpm i think, unless my understanding is screwed up.
Vcc would be attached to your 12 volt battery source. Fin would attach to some sort of sensor that pulses each time the engine goes through one revolution(sense the No. 1 spark plug firing). Make sure that the pulse in not grater than Vcc so that you don't damage the input circuit of the chip.my understanding is Vcc is voltage supply so the 12 volt Vcc would be perfect with the car battery, Fin is the frequency signal, so i just connect th tachometer signal to this?
You will also need a way to mount the components. Check out prototype circuit boards.and i would also need 2 capacitors and 3 resistors for this to work?
Yes. Attach your voltmeter across this resistor.i'm supposed to take the voltage output from right before the 10k (10,000?) ohm resistor which then goes to ground?
No. That is the symbol for AC (Alternating Current). In you case, the AC will actually be more of a square-wave instead of sinusoidal.what is that curvy line in a circle by Fin, is that a fuse?
