| Thread Closed |
Sliding metal plate on a slanting roof |
Share Thread | Thread Tools |
| Nov4-06, 03:39 PM | #1 |
It is said that a metal plate kept on a slanting roof (say made of
concrete) slides down (although slightly) over a period of many days due to repeated heating and cooling during the day and night. Ofcourse it is assumed that friction is sufficient to prevent sliding due to gravity alone. Somehow repeated expansion and contraction of the plate during the day and night causes this phenemonon. Can anyone expalin what is happening? |
| Nov4-06, 03:39 PM | #2 |
in article <1160011858.467520.295640@c28g2000cwb.googlegroups.com>,
jumanicus <vishwesh.muzumdar@rediffmail.com> wrote: |It is said that a metal plate kept on a slanting roof (say made of |concrete) slides down (although slightly) over a period of many days |due to repeated heating and cooling during the day and |night. Ofcourse it is assumed that friction is sufficient to prevent |sliding due to gravity alone. Somehow repeated expansion and |contraction of the plate during the day and night causes this |phenemonon. Can anyone expalin what is happening? it seems quite plausible that even when friction is sufficient to prevent sliding-due-to-gravity-alone, it may be insufficient to prevent expansion-and-contraction-of-the-plate-due-to-heating-and- cooling. so as the plate expands and contracts (while the concrete _doesn't_ expand and contract anywhere nearly as much), something's got to give- either the higher edge of the plate or the lower edge of the plate must slip against the concrete. during expansion, it's the slipping downwards of the lower edge that's more energetically favorable than the slipping upwards of the upper edge, and during contraction it's the slipping downwards of the top edge that's energetically more favorable than the slipping upwards of the lower edge. (that's the way gravity works: going downwards is generally energetically more favorable than going upwards.) thus the plate inches down the roof like an inchworm, expanding and contracting while preferentially moving downwards rather than upwards. thus even when gravity isn't sufficient to _cause_ slippage all by itself, it can be sufficient to determine the _direction_ of slippage caused by something else. -- jdolan@math.ucr.edu |
| Nov4-06, 03:39 PM | #3 |
James Dolan <jdolan@math.ucr.edu> writes
>thus the plate inches down the roof like an inchworm, expanding and >contracting while preferentially moving downwards rather than upwards. This is the reason given for cellular polycarbonate roofing sheets (found on conservatories, typically) for working their way out despite well clamped edges. Its easily fixed with one screw at the bottom end as per the installation instructions. -- Oz This post is worth absolutely nothing and is probably fallacious. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Sliding metal plate on a slanting roof
| sliding down a roof | Introductory Physics Homework | 1 | ||
| Can a conducting metal plate connected to a +ve terminal of a battery gets charged? | General Physics | 2 | ||
| Magnetic field generated by a metal plate | Introductory Physics Homework | 1 | ||
| thermal expansion of a metal plate | Introductory Physics Homework | 1 | ||
| parallel plate metal waveguide | General Physics | 1 | ||
