Proving Wedge Product Property for Alternating Tensors
The discussion revolves around the properties of the wedge product on alternating tensors, specifically the relationship expressed as w ^ n = (-1)^(kl) * n ^ w, where w is a k-alternating tensor and n is an l-alternating tensor. Participants explore the implications of this property and the challenges in proving it.
  • One participant expresses difficulty in proving the wedge product property and presents a formula involving the alternating tensor and tensor product.
  • Another participant questions the validity of the initial formula used, suggesting that w and n are already alternating tensors and not tensor products.
  • Several participants discuss the implications of rearranging indices in alternating tensors and the resulting sign changes due to antisymmetry.
  • A participant provides a counterexample involving specific values of k and l, attempting to demonstrate a discrepancy in the expected number of interchanges.
  • Another participant clarifies that the total sign change when moving indices is related to the product of k and l, and offers a method to count interchanges more systematically.
  • There is a discussion about the definition of alternating tensors and the properties of their indices when rearranged.
Participants do not reach a consensus on the proof of the wedge product property. There are competing views on the correct approach to understanding the sign changes and interchanges involved in the rearrangement of indices.
Some participants highlight the importance of distinguishing between tensor products and alternating tensors, and there are unresolved questions about the assumptions made in the proofs and counterexamples presented.
This discussion may be of interest to those studying differential forms, alternating tensors, and the mathematical properties of wedge products in advanced mathematics or theoretical physics.
ak416
This has to do with the wedge product ^ on alternating tensors. I can't seem to prove w ^ n = (-1)^kl * n ^ w. where w is a k alternating tensor and n is an l alternating tensor.
I know w ^ n = (k+l)!/(k! l!) * Alt(w x n) where x is the tensor product.
Now, Alt(wxn) (v_1,...,v_k+l) = 1/(k+l)! * (sum over all s in Sk) ( sgn(s) * (w x n) (v_s(1),...,v_s(k+l) )
= 1/(k+l)! * (sum over all s in Sk) ( sgn(s) * (n x w) (v_s(k+1),...,v_s(k+l),v_s(1),...,v_s(k)) )
Note Sk is the set of all permutations of the numbers 1,...,k.
Now if I let s' be the permutation such that
Alt(w x n) = 1/(k+l)! * (sum over all s in Sk) ( sgn(s) * (n x w) (v_s'(1),...,v_s'(k+l)) )
then shouldn't Alt(w x n) = 1/(k+l)! * (sum over all s' in Sk) ( (-1)^m * sgn(s') * (n x w) (v_s'(1),...,v_s'(k+l)) )
where m is the number of transpositions needed to transform (k+1,...,k+l,1,...,k) to (1,...,k+l). Because if this is true then doesn't the property imply that m = l*k. And this isn't true. So what am i doing wrong here?
isn that more or less the definition of alternating?
definition of an alternating tensor is that when you swap any of its input vectors, you get the same result but times negative one. (like the determinant).
It's not right to use w ^ n = (k+l)!/(k! l!) * Alt(w x n), because w and n are already forms, or alternative tensors (not the tensor products!).
It is easy to prove your formula using just the bases of rank k and l and the simple relation dx^i ^ dx^j=-dx^j ^ dx^i.
think about it, if you have a pair of vectors of form (a1,...,ak,.b1,...,bl) and you rearrange it to be of form (b1,...bl,a1,...ak) how many interchanges jhave you made? if the aNSWER IS KL, THEN YOU ARE DONE.
ya i tried that. But take for example k = 3, l = 7.
so you have (1,2,3,4,5,6,7,8,9,10,11) you want (5,6,7,9,9,10,11,1,2,3,4)
step 1: transform this to (8,9,10,11,5,6,7,1,2,3,4) (4 interchanges)
step 2: transform to (5,6,7,11,8,9,10,1,2,3,4) (3 interchanges)
step 3: transform to (5,6,7,8,11,9,10,1,2,3,4) (1 interchange)
step 3: transform to (5,6,7,8,9,11,10,1,2,3,4) (1 interchange)
step 3: transform to (5,6,7,8,9,10,11,1,2,3,4) (1 interchange)
total: 10 interchanges
k*l = 21
what is wrong with this counterexample?
Suppose that you have indices [itex](a_1,\ldots,a_k,b_1,\ldots,b_l)[/itex] and that we want to swap around the indices [itex]b_1[/itex] and [itex]a_k[/itex]. Because of the antisymmetry we have
[tex](a_1,\ldots,a_k,b_1,\ldots,b_l) = (-1)(a_1,\ldots,b_1,a_k,\ldots,b_l)[/tex]
Agreed? Now suppose that we want to go one further and move [itex]b_1[/itex] into the position of [itex]a_{k-1}[/itex]:
[tex](a_1,\ldots,a_k,b_1,\ldots,b_l) = (-1)(a_1,\ldots,a_{k-1},b_1,a_k,\ldots,b_l) = (-1)^2(a_1,\ldots,b_1,a_{k-1},a_k,\ldots,b_l)[/tex]
So, we've moved [itex]b_1[/itex] two places to the left and obtained a factor of [itex](-1)^2[/itex]. In fact, we can move [itex]b_1[/itex] [itex]k[/itex] places to the left to get
[tex](a_1,\ldots,a_k,b_1,\ldots,b_l) = (-1)^k(b_1,a_1,\ldots,a_k,b_2,\ldots,b_l)[/tex]
We've now managed to move one of the [itex]b[/itex] indices completely to the left. However, we'd also like to move the rest of them. It doesn't take a great deal of thought to convince yourself that if you also now move [itex]b_2[/itex] to the left by [itex]k[/itex] places you obtain
[tex](a_1,\ldots,a_k,b_1,\ldots,b_l) = (-1)^{2k}(b_1,b_2,a_1,\ldots,a_k,b_3,\ldots,b_l)[/tex]
So if you move two of the [itex]b[/itex] indices to the left you get a factor of [itex](-1)^{2k}[/itex]. In fact, if you move all [itex]l[/itex] of the [itex]b[/itex] indices to the left (keeping them in their original order), it should then be straightforward to see that you get
[tex](a_1,\ldots,a_k,b_1,\ldots,b_l) = (-1)^{l\cdot k}(b_1,\ldots,b_l,a_1,\ldots,a_k)[/tex]
Does this help you to see what's going on when you swap around the indices?
If you now return to the original question that you asked, suppose that we denote the space of [itex]k[/itex]-forms over some space [itex]V[/itex] by [itex]\Lambda^k(V)[/itex]. Then, given [itex]\alpha\in\Lambda^k(V)[/itex] and [itex]\beta\in\Lambda^l(V)[/itex], we know from the definition of the wedge product that [itex]\alpha\wedge\beta\in\Lambda^{k+l}(V)[/itex]. The important thing about differential forms is that they are simply machines into which you feed vectors. For example, if you have a [itex]k[/itex]-form [itex]\alpha[/itex], then you can get a number out of it by letting it act on [itex]k[/itex] vectors [itex]X_{(1)},\ldots,X_{(k)}[/itex]:
[tex]\alpha:(X_{(1)},\ldots,X_{(k)})\mapsto\alpha(X_{(1)},\ldots,X_{(k)}) \in \mathbb{F}[/tex]
where I've denoted a typical field by [itex]\mathbb{F}[/itex]. In physics, we're usually interested in the case where [itex]\mathbb{F}=\mathbb{R}[/itex]. However, the differential form has the important property that if you swap around the order of any two of the input vectors, then you get a factor of (-1). For example,
[tex]\alpha(X_{(1)},X_{(2)},\ldots,X_{(k)}) =(-1) \alpha(X_{(2)},X_{(1)},\ldots,X_{(k)})[/tex]
This is exactly analogous to what I said at the start about swapping around indices. Knowing this, it's really easy to see that you have the desired result:
[tex]\alpha\wedge\beta = (-1)^{k\cdot l}\beta\wedge\alpha[/tex]
k*l = 21
It's not quite right
you have k = 3, l = 8 or (1,2,3)^(4,5,6,7,8,9,10,11) you want (4,5,6,7,8,9,10,11)^(1,2,3).
Remember (1,2,3) and (4,5,6,7,8,9,10,11) are 3-form and 7-form, or (1,2,3) is (1^2^3) and (4,5,6,7,8,9,10,11) is (4^5^6^7^8^9^10^11).
Step 1 : you move 4 to the left through the form (1^2^3) and each time you have to change the sign. The sign will be (-1)^3 (here "^" is power)
Step 2 : repeat this procedure for 5,6,...,11. The total sing will be (-1)^(3 *8). In other words (-1)^(k*l).
Look,
coalquay404 has discribed it in more general way.
whoops did i just say 7+3 = 11. Ok i understand now coolquay. My method isn't really a counterexample because 8*3 = 24 and it is still even like 10. Your way of interchanging only the entries beside each other is good because it proves that its l*k interchanges. thanks.
if you have a pair of vectors of form (a1,...,ak,.b1,...,bl) and you rearrange it to be of form (b1,...bl,a1,...ak), then each one of the l b's has moved past the k a's. done.
What do you mean by a "pair" of vectors? Each of the indices represents one vector input into the [itex](k+l)[/itex]-form so there are [itex]k+l[/itex] vectors involved, not just a pair.
  • · Replies 17 ·
