Momentum/Impulse Graph Finding Velocity
  • Thread starter Thread starter duke1
    Graph Velocity
The discussion revolves around a problem involving momentum and impulse, specifically focusing on determining the velocity of a ball after a certain time period based on a provided impulse graph. The ball has an initial mass and velocity, and participants are trying to interpret the graph to find the final speed after 4 seconds.
  • Participants express uncertainty about how to read the impulse graph and its implications for momentum. There are discussions about the nature of the graph, with some suggesting it resembles a square wave or triangle wave. Questions arise regarding the correct interpretation of the graph and the application of impulse and momentum concepts.
The discussion is ongoing, with participants seeking clarification on the graph and its approval status. Some guidance has been offered regarding the relationship between impulse and momentum, but there is no consensus on how to proceed effectively. Multiple interpretations of the graph are being explored.
Participants note that the graph has not loaded for some, which may hinder their ability to analyze the problem fully. There are also mentions of specific tick marks and values on the graph that are under discussion, indicating potential confusion about the graph's details.
duke1
Momentum/Impulse Graph...Finding Velocity
A 0.125 kg ball, moving in the positive direction at 12 m/s, is acted on by the impulse shown in the graph in Figure 9-16 What is the ball's speed at 4.0 s?
If the picture doesn't load as an attachment I'll have to try it again.
Okay so I'm not sure where to start when lookin at this graph. I think I start with finding the original momentum which is 1.5. The main problem is reading the graph. Again with this one I'm just stuck with how to read the graph.
bp
Can someone point me in the right direction?
The graph does not load. Try again.
ehild
It says they are pending approval.
Is it a velocity-time graph?
Nope there is Force in the Y and Time in the X
On the Y there are 3 tick marks in this order top to bottom 2 0 -2.
On the X there are the numbers 1-4 (time in seconds).
From 0-1 in the X it follows the 0 on the Y, from 2-3 there is an impulse that goes up to the 2 (Coordinate 2,2) in the Y then from 3-4 it remains on 0 force. Probably nm help but not sure what else to do like getting it approved or w/e.
Does anyone know how to get the image approved?
So it looks like a square wave, right? 0, then 2, then 0? Do you know the impulse formula? If you do, you have all but 1 variable.
triangle wave and the point is between 1-3 on top of the 2 in the X...ive tried that but it doesn't give me the answer.
i can find initial momentum but how do i find speed at 4 seconds?
Impulse is the change in momentum. Find the area under the curve and add that to the initial momentum
that didnt do it
  • · Replies 19 ·
