How can I show that G=8pT implies the equivalence principle ?
The discussion revolves around the relationship between the Einstein field equations (EFE) and the equivalence principle in general relativity. Participants explore how the equation \( G = 8\pi T \) relates to the equivalence of gravitational and inertial forces, examining theoretical implications and interpretations.
  • Some participants suggest that the equivalence principle is implied by modeling gravitational interactions as curvature of space-time rather than as a force acting on flat space-time.
  • Others argue that the EFE indicates mass-energy curves space-time, leading to the conclusion that freely falling particles experience no force, thus supporting the equivalence principle.
  • A participant questions the conclusion that a freely falling particle experiences no acceleration, proposing that comparisons between accelerated frames and gravitational frames could clarify the equivalence principle.
  • Some participants assert that the EFE does not imply the equivalence principle; rather, it is the equation of motion of matter that does, provided matter is minimally coupled to gravity.
  • There is a discussion about the implications of minimal coupling and how it relates to the paths of matter and the influence of the metric on those paths.
  • Participants mention that there are many solutions to the EFE beyond the perfect fluid solution, and they discuss the implications of energy-momentum conservation in relation to the equivalence principle.
  • One participant raises a question about the cosmological constant solution and its adherence to the equivalence principle.
Participants express multiple competing views regarding the implications of the EFE and the equivalence principle. There is no consensus on whether the EFE alone implies the equivalence principle, and the discussion remains unresolved.
Participants note limitations in understanding the implications of the EFE and the definitions of terms such as "equation of motion of the gravitational field" and "minimal coupling." There are references to specific equations and concepts that require further clarification.
This discussion may be of interest to those studying general relativity, particularly in understanding the nuances of the equivalence principle and the Einstein field equations.
lalbatros
If I am asking this question, this is maybe a proof that I need a strong "back-to-the-basics".
Could you give the way?
Thanks,
Michel
Equivalence of acceleration and gravitational forces? I had the impression that principle is basically implied, before the EFE (which you quote) is imposed, when you start by modelling your gravitational interaction as a curvature of space-time instead of as a force on top of (flat) space-time. Then the EFE is found so as to match that curvature (in certain limits) quantitatively to accelerations that are measured or have been predicted by Newtonian gravity (though we could instead have found a different field equation, or modified the EFE, and still retain the equivalence principle).
Perhaps more the answer you want is: If you take the EFE, it implies that mass-energy curves space-time in such a way that masses will accelerate towards one another without any other forces (and therefore there is absolutely nothing locally to distinguish between the acceleration you feel a constant distance from the Earth and the acceleration you might feel on a rocket ship in deep space). Indeed, on Earth the normal electrostatic force that ground applies to your feet (pushing you up to prevent you falling) is no different to the force that might be produced by a rocket engine's thrust or by the floor of an elevator elsewhere.
Consider the space-time around [itex]x_{\mu}[/itex] where the following holds:
[tex]G_{\mu\nu} = 8\pi GT_{\mu\nu}[/tex]
which gives
[tex]G^{\mu}_{\nu;\mu} = 8\pi GT^{\mu}_{\nu;\mu}[/tex]
As [tex]G^{\mu}_{\nu;\mu} = 0[/tex] [The Bianchi identities]
therefore [tex]T^{\mu}_{\nu;\mu} = 0[/tex]
[itex]T^{\mu}_{\nu;\mu}[/itex] describes the force density acting at [itex]x_{\mu}[/itex], in other words the force density acting on a freely falling particle is zero, hence it suffers is no acceleration in the freely falling frame of reference and the space-time is Minkowskian in a sufficiently small area around the point [itex]x_{\mu}[/itex].
Garth
Garth,
I don't understand why you can conclude this:
... in other words the force density acting on a freely falling particle is zero, hence it suffers is no acceleration in the freely falling frame of reference ...
I think that the answer may be simple or even obvious. I thought first that the answer would be obtained by comparing motions in two frames (accelerated without gravitation and another with gravity) and concluding that physics is the same. I also considered that it could be simply related to the invariance of the equations.
Thanks to help me on that,
Michel
lalbatros said:
Garth,
Michel
Yes it is obvious - if you think about it a bit!
If there is curvature but there is no force denstiy acting on a 'test particle' at a particular location then there is no force acting on it and therefore its four-momentum is constant.
If there is no curvature at a particular location the test particle's four-momentum is also constant.
Hence the EEP.
Garth
The Einstein equation, which is the equation of motion of the gravitational field, does NOT imply the equivalence principle. Instead, it is the equation of motion of MATTER that implies the equivalence principle, provided that matter is MINIMALLY coupled to gravity (i.e. to the metric tensor).
The conservation of energy-momentum implies the equivalnce principle only if [tex]T_{\mu\nu}[/tex] is specified and equal to the quantity that corresponds to the minimal coupling of matter to gravity.
I do not think that statement makes sense does it?
What does "equation of motion of the gravitational field" mean?
The Einstein gravitational field equation
[tex]R_{\mu \nu} - \frac{1}2{}g_{\mu \nu}R = 8\pi GT_{\mu \nu}[/tex]
connects the curvature of space-time with the distribution of mass, energy and stress.
The equation of motion of matter is derived from this equation.
viz: from the Bianchi identities
[tex]G^{\mu}_{\nu ;\mu} = 0[/tex] therefore
[tex]T^{\mu}_{\nu ;\mu} = 0[/tex]
which can then be solved for particular cases such as that of a perfect fluid:
[tex]T_{\mu \nu} = \rho u_{\mu}u_{\nu} + p(g_{\mu\nu} + u_{\mu}u_{\nu})[/tex]
Further more, the statement "matter is MINIMALLY coupled to gravity (i.e. to the metric tensor)" would imply the metric does not influence the paths of matter at all.
Garth
There are many many other solutions besides the perfect-fluid solution. Einstein equation is obtained by varying action with respect to metric. To obtain the matter equation of motion, you need to vary action with respect to matter degrees of freedom. The energy-momentum conservation is NOT the equation of motion.
Think also about the following. One of the solutions of the energy-momentum conservation equation is the "cosmological constant" solution
[tex]T_{\mu\nu}(x)=g_{\mu\nu}(x)\lambda .[/tex]
Does it obey the equivalence principle?
Did you ever heard about the notion of "minimal coupling"?
In the case of gravity, minimal coupling means that the only way the nontrivial metric enters the equations is through replacing the ordinary derivatives by covariant derivatives.
Demystifier,
You are right about the Einstein's equations, I realized that shortly after posting.
Clearly I have to check the EP on the equations of motion.
Would you have a reference on the web that shows that explicitely?
Thanks,
Michel
Not really.
Nevertheless, if you need a pedagogic introduction to general relativity, I recommend
http://arxiv.org/abs/gr-qc/9712019
Agreed, that is why I said "such as"
Agreed, varying the action in 4D space-time necessarily results in the conservation of energy-momentum because the method is true for generalised coordinates.
In which case, in the case of no external forces acting, you disagree with Wald "General Relativity" see Eq.4.3.6 and the discussion on page 73.
Obviously in GR it does locally.
Could you clarify what you meant by "the equation of motion of the gravitational field"? Thank you.
Garth
I am familiar with the expression being used referring to a scalar field, in which case if the scalar field is minimally coupled then its presence affects only the curvature of space-time and does not perturb test particles from their geodesic world-lines through that space-time.
I have never used "minimal coupling" in that sense and I find its use a little over-redundant. Which authors do use it as such?
Garth
Garth said:
1. In which case, in the case of no external forces acting, you disagree with Wald "General Relativity" see Eq.4.3.6 and the discussion on page 73.
2. Could you clarify what you meant by "the equation of motion of the gravitational field"? Thank you.
1. Of course, but I was talking generally, not about the special case without external forces.
2. I meant the equation that one obtains by varying the gravitational field in the total action.
It's not so much that it's the field equations G=kT themselves that imply the Equivalence Principle. It is more about that those equations (or alternate equations like them) are formulated on a generally-curved spacetime.
http://relativity.livingreviews.org/open?pubNo=lrr-2001-4&page=node3.html
This terminology perhaps is not common in GR, but is common in gauge theories. And you certanly know that GR can be viewed as a gauge theory.
Agreed, and [itex]G_{\mu\nu}[/itex] describes that curvature.
Garth
Garth
[itex]G_{\mu\nu}[/itex] describes part of that curvature.
The point I was making is that the Einstein Field Equations are not required for the so-called Equivalence Principle.
Agreed, the Riemannian fully describes the curvature.
Yes indeed, the WEP is satisfied in Newtonian theory and the Brans-Dicke Field Equations equations satisfy the SEP, but noting G varies with position in that theory.
The OP, however, was asking the question the other way round, that is, does the EFE imply, not is it required for the EEP.
Garth
  • · Replies 73 ·
  • · Replies 48 ·
  • · Replies 36 ·
  • · Replies 36 ·
  • · Replies 53 ·
