Moonrock gravitationally same as earthrock?
  • Context: Graduate
  • Thread starter Thread starter ianbell
The discussion revolves around the hypothesis that moonrock may be gravitationally attracted to the moon differently than earthrock. Participants explore the feasibility of an experiment to measure this difference, the implications of such measurements, and the underlying assumptions about gravitational attraction.
  • Some participants propose an experiment using a balance scale to compare the gravitational attraction of moonrock and earthrock during a lunar orbit cycle.
  • Others argue that the gravitational pull difference would be extremely small and likely beyond the precision of available balance scales.
  • A participant mentions that previous tests have shown mass does not attract differently to different bodies, suggesting a null result would be inconclusive.
  • Some participants question the basis for believing there would be a difference, noting that both moonrock and earthrock are composed of similar materials.
  • One participant introduces the idea that variations in material properties, such as ferromagnetic homogeneity, could lead to differences in gravitational attraction.
  • Another participant suggests that fluidity and quantum effects might also play a role in the gravitational interaction between different types of rock.
  • A participant expresses skepticism about the likelihood of such an experiment being conducted, citing potential challenges in measuring subtle differences.
Participants do not reach a consensus on whether moonrock and earthrock would exhibit different gravitational attractions. Multiple competing views remain regarding the feasibility of measuring such differences and the underlying assumptions about gravitational interactions.
Limitations include the precision of measurement equipment, the assumptions about gravitational attraction being uniform across different materials, and the potential influence of material properties on gravitational interactions.
ianbell
To test the hypothesis that moonrock is gravitationally attracted to the moon slightly more than is earthrock one could measure the deviations of a balance scale weighing NASA-provided moonrock against an equal (earth) weight of (say) granitedust from horizontal during a lunar orbit cycle and compare this to the deviations of the balance when the scale is balanced by two equal weights of granitedust.
I remember reading somewhere that this or a similar experiment has been done and proven negative (consistent with G being the same for all matter) but can't now find the details.
Can anybody help? TIA.
russ_watters said:
What is the basis for your reasoning?
In the case of weighing to equal weights of granitedust, as the moons orbit passes nearer the scales it will have a very slight unbalancing effect on it, the moon always being slightly nearer one end than the other unless the scales are psotioned extremely carfully with regard to the lunar orbit. But if one of the wieghts is moonrock that is hypotheised more attracted to the moon than is granite, the imbalance will be more pronounced.
But I'm not sure how my "reasoning" is relevant. Its an obvious experiment which I think has been conducted.
The Moon is 360,000,000 meters away. It's Mass is 7 x 10^22 kg. Here at the earth,the moon pulls on a 1 kg rock with a strength of 4x10^-5 N, which is 0.000008 lbs of force.
Your experiment requires finding the difference between the forces on moon rock and Earth rock, which (even if plausible) would be a tiny fraction of this tiny amount. Balance scales do not have this kind of precision. A "null" result is one that is inconclusive as this experiment would be.
Contrary to your description, the difference in pull would be maximized when the moon is straight overhead above the scale (unless the scale has balance pans hundreds of kilometers apart).
I have never heard of this speculation nor this experiment. I don't think NASA would have bothered to carry it out. Sounds like someone's "thought experiment" to me. Other tests have proven conclusively that mass will not attract differently to different bodies.
Disturbances due to different moonrock/earthrock attractions yes. Deviations due to the moon imbalancing the earthrock/earthrock balance no.
Can you give details please?
Why do you think there would be a difference?
Earthrock and Moonrock are made of the same stuff.
Even the original source of both is the same.
Try looking up Etovos experiments.
Why would they be the same? If I took two pieces of iron from different parts of the Earth's core, and took two cubic centimeter cubes from one and one from the other I would expect the forces between the two "neighbour" cubes to be different to that between distant sourced cubes because the ferromagnetic homogeniety are likely to differ. You might argue that that's electromagnetism rather than gravity but as I suspect
gravity to be an artifact of electromagenetism that's not an effective rejoinder. Then there is the question of fluidity. I would expect granitedust to be more attracted to the moon than granite because the lunar pull would draw the dust toward the moon slightly, dehomegenising its density in favour of the attraction. There is the possibility of quantum entanglements persisting between separated objects, and also the possibility of resonance effects between distant but similar atomic arrangements.
Even the original source of [earth and moon] is the same.
Yes, but there has been a separation; possibly according to kind.
Ah yes, thanks.
I have no idea what you think you are talking about.
Oh, I get it now. Goodbye.
This thread will probably be locked soon.
I agree that the experiment you describe would show any difference between the gravitational attraction of the Earthrock to the Moon and that of a Moonrock, if equipment sensitive enough to take such a measurement exists (I think that it may).
However, I've never heard of anyone performing such an experiment. I would expect the average scientist (who would be expecting a negative result) to be unwilling to waste the time since, upon recording a negative result, he would only find his result challenged by those who say the difference was there, but too subtle to be recorded by current equipment.
You seem to believe that a difference does exist. Do you know others who share this belief? They would be the ones to attempt such a measurement, since they would be expecting a positive result (and just one verifiable positive result would prove the point).
15K
  • · Replies 21 ·
  • · Replies 66 ·
  • · Replies 20 ·
18K
  • · Replies 86 ·
9K
