Defining GR with Poisson Bracket
  • Context: Graduate
  • Thread starter Thread starter Karlisbad
    Bracket Gr Poisson
The discussion revolves around the formulation of General Relativity (GR) using Poisson brackets, specifically exploring the relationship between the metric \( g_{ab} \) and its conjugate momenta \( \pi_{ab} \). Participants examine whether GR can be expressed in a Hamiltonian framework and the implications of such a formulation, including the necessary conditions and potential limitations.
  • Some participants propose that GR can be defined using Poisson brackets, suggesting equations of motion for the metric and momenta.
  • Others question the definition of \( \pi_{ab} \) and whether the Hamiltonian formulation can be derived from the least action principle.
  • It is noted that a Hamiltonian formulation exists, but it requires a split between space and time, using the spatial metric \( h_{ab} \) instead of the space-time metric \( g_{ab} \).
  • One participant references Wald's textbook as a source for the Hamiltonian formulation, while another critiques Wald's treatment of the subject, particularly regarding the relevance of Poisson brackets and the action used.
  • There is a detailed discussion about the Einstein-Hilbert action and the necessity of including boundary terms for a well-posed variational principle, with some participants arguing that Wald's formulation is insufficient without these corrections.
Participants express differing views on the adequacy of Wald's treatment of the Hamiltonian formulation of GR and the importance of boundary terms in the action. There is no consensus on whether Wald's approach is correct or sufficient, indicating ongoing debate.
Some participants highlight limitations in Wald's action, particularly in non-compact manifolds, and the implications of these limitations for deriving field equations. The discussion reflects a range of assumptions and interpretations regarding the formulation of GR.
Karlisbad
If you have the metric [tex]g_{ab}[/tex] , [tex]\pi _{ab}[/tex] as the metric and "generalized momenta", my question is if you can define GR using Poisson Bracet:
[tex]\dot g_{ab} =[g_{ab},H][/tex]
[tex]\dot \pi _{ab}=[\pi _{ab},H][/tex]
and hence use these equations to obtain and solve the metric.:shy:
Karlisbad,
I don't understand precisely your question.
Specially, what are the [tex]\pi _{ab}[/tex] ?
However, since GR derives from a least action principle, I guess that it can be written in an Hamiltonian way. (is it true that "least action" => "hamilton equations" ?)
If this is right, could it be done along the usual lines?
Michel
There exists a Hamiltonian formulation of general relativity. The "q", from which the "p" is defined, is the spatial metric [itex]h_{ab}[/itex], but not the space-time metric [itex]g_{ab}[/itex]. For the Hamiltonian formalism it is necessary to split space-time into space and time.
Somebody else asked this question recently in the Diff. Geom. forum. My answer can be found here. Note, however, that some of my factors of [itex]\sqrt{g}[/itex] in the integrals are in fact incorrect. For example, if you take the Hamiltonian density [itex]\mathcal{H}[/itex] to be of weight one, then the Hamiltonian is
[tex]H = \int_\Sigma d^3x \mathcal{H}[/itex]<br /> <br /> Then the standard equations of motion for the three-metric and momenta are given by<br /> <br /> [tex]g_{ij}(\vec{x}) = \{g_{ij}(\vec{x}),H\} = \int_\Sigma d^3x' \{g_{ij}(\vec{x}),\mathcal{H}(\vec{x}')\},[/tex]<br /> [tex]\pi^{ij}(\vec{x}) = \{\pi^{ij}(\vec{x}),H\} = \int_\Sigma d^3x' \{\pi^{ij}(\vec{x}),\mathcal{H}(\vec{x}')\}.[/tex][/tex]
Wald describes the desired formulation
Hi, Karlisbad,
Just wanted to point out that the Hamiltonian formulation you seek is described (correctly) in the textbook by Wald, General Relativity.
Chris Hillman
Chris Hillman said:
Hi, Karlisbad,
Chris Hillman
I don't think that's entirely true. IMO, Wald makes a hash of describing the Hamiltonian approach. Of particular relevance to the OP, Wald also doesn't discuss the evolution equations in terms of the Poisson brackets of the metric and its conjugate momentum, and makes only a half-hearted attempt at explaining how Poisson brackets are of relevance to the constraints.
I hate that appendix in Wald. The fact that he uses an incorrect action for GR is, frankly, embarrassing.
Please enlighten us.
Well, Wald is correct to state that the basic action from which the field equations can be derived is the Einstein-Hilbert action:
[tex]S_{\textrm{E-H}}[g] = \frac{1}{2\kappa}\int_\mathcal{M} d^4x\,\sqrt{-g}R + S_M,[/tex]
where [itex]S_M[/itex] is a (possibly derivatively coupled) matter action. This is all fine if [itex]\mathcal{M}[/itex] has no boundary. However, if [itex]\partial\mathcal{M}\ne\emptyset[/itex] then in order for the variational principle to be well posed one needs to add the Gibbons-Hawking-York boundary term [itex]S_{\partial\mathcal{M}}[g][/itex]. Then we have
[tex]S[g] = \frac{1}{2\kappa}\int_\mathcal{M} d^4x\sqrt{-g}R + \frac{1}{\kappa}\int_{\partial\mathcal{M}}d^3y \sqrt{|h|}\textrm{tr}K + S_M,[/tex]
where [itex]h_{ij}[/itex] is a three-metric on [itex]\partial\mathcal{M}[/itex] and [itex]\textrm{tr}K=h^{ij}K_{ij}[/itex] is the trace of the extrinsic curvature of [itex]\partial\mathcal{M}[/itex].
In fairness, Wald does stress the importance of this boundary contribution to the action, but he concludes that the action above is sufficient to derive sensible field equations. This is untrue. If you evaluate the gravitational action for, say, flat spacetime, then [itex]S_{\textrm{E-H}}[g]=0[/itex]. However, for flat spacetime [itex]S_{\partial\mathcal{M}}[g][/itex] is divergent, making the action effectively infinite. Thus, the action that Wald uses is actually ill defined except when [itex]\mathcal{M}[/itex] is compact. In order to overcome this, one needs to introduce a further correction to the action, meaning that the true action for general relativity is
[tex]S = S_{\textrm{E-H}}[g] + S_{\partial\mathcal{M}}[g] + S_M - \frac{1}{\kappa}\int_{\partial\mathcal{M}} d^3y\sqrt{|h|}K_0[/tex]
where [itex]K_0[/itex] is the extrinsic curvature of [itex]\partial\mathcal{M}[/itex] embedded in Minkowski space.
  • · Replies 37 ·
  • · Replies 19 ·
