Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Science Education > Homework & Coursework Questions > Introductory Physics
Reply
image Projectile Motion assignment - Building a projectile launcher Share It Thread Tools Search this Thread image
Old Nov11-06, 08:35 PM                  #1
Hans
Hans is Offline:
I need help/advice on building a simple projectile launcher, for a tennis ball or smaller object.
I need to calculate the angle so it must be something that shoots fairly straight (ballista?).
Any links or advice on this would be much appreciated
~Hans
Old Nov12-06, 08:32 AM                  #2
Astronuc
PF Mentor
Astronuc's Avatar
Astronuc is Online:
One could search Google with "ballista".
Is the device supposed to be mechanical, e.g. spring (bow) or lever (catapault, trebuchet)?
The alternative would be a propellant such as compressed gas or explosive chemcial reaction (which is hazardous).
Old Nov12-06, 10:25 AM                  #3
andrevdh
andrevdh is Offline:
Recognitions:
Homework Helper Homework Helper
Use a vacuum cleaner connected to the front of a long PVC pipe. The pipe from the vc connets via a T piece to the barrel that launches the ball. Seal the front of the pipe with a piece of paper and insert the ball in the other end. The vc will then create a low pressure in front of the ball when it is inserted at the other end. Air pressure then pushes it along the barrel (although I like to think that it is carried along by the air stream). The ball will fly pass the section where the vacuum cleaner is connected to the pipe and push the piece of paper out of the way. With a setup like this one might introduce some spin on the ball as it passes through the barrel. This will then cause it to deflect a bit (usually downwards) due to the Magnus force.
Old Oct21-09, 04:59 PM                  #4
Penguin10
Penguin10 is Offline:
Re: Projectile Motion assignment - Building a projectile launcher
I don't know about you, but I'm probably building a trebuchet. One, because they are supposedly very accurate. Two, I can't find anything else on the Internet. Three, the air launcher would take too much time to set up in between launches. Four, I don't think my teacher would appreciate it if I brought a vacuum cleaner into class.
image image
Reply
Thread Tools
Similar Threads for: Projectile Motion assignment - Building a projectile launcher
Thread Thread Starter Forum Replies Last Post
**URGENT** Help on a PROJECTILE LAUNCHER Project Amadeus Introductory Physics 1 Nov8-07 07:17 PM
Projectile Launcher Project.. tinnguyen123 Introductory Physics 1 Nov6-07 11:32 PM
Projectile Launcher. helpwithphysics General Physics 9 May24-06 04:07 AM
Projectile Launcher cscott Introductory Physics 3 Oct8-05 07:58 PM
Uniform Circualr Motion with Projectile Motion problem (Extremely confusing): VinnyCee Introductory Physics 4 Sep27-04 07:29 AM
Powered by vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
