| Thread Closed |
A paradox inside Newtonian world |
Share Thread | Thread Tools |
| Feb18-07, 08:20 AM | #494 |
| Feb18-07, 12:39 PM | #495 |
The right side force to mass point m is:
(G*m*m/2)/(d*d)+(G*m*m/4)/(d*d*1.1*1.1)+...+... = (0.992*G*m*m)/(d*d) What else do you need? |
| Feb18-07, 01:55 PM | #496 |
[tex]\sum_{i=0}^{\infty} \frac{Gm^2}{2^{i+1} d^{2} \sum_{j=0}^{i} 10^{-j} }= \frac{0.922 Gm^2}{d^2}[/tex] Im just turning your ...'s into sums. |
| Feb19-07, 01:37 AM | #497 |
Looks quite good to me.
| Feb20-07, 12:30 PM | #498 |
but its not right. Left side approaches zero.
| Feb20-07, 02:28 PM | #499 |
The left side is quite weak, but I don't care. At least not more than for the OMF's calculation somewhere above.
But the right side is correct and that's enough. |
| Feb20-07, 04:15 PM | #500 |
how is it correct? i was just putting what you said into calculable terms. How did you get that number, please show the math.
| Feb21-07, 12:23 PM | #501 |
I repeat myself:
>> (G*m*m/2)/(d*d)+(G*m*m/4)/(d*d*1.1*1.1)+(G*m*m/8)/(d*d*1.11*1.11)+...+... = (0.992*G*m*m)/(d*d) It's trivial to see that. |
| Feb24-07, 03:00 AM | #502 |
Even
(G*m*m/2)/(d*d)+(G*m*m/4)/(d*d*1.1*1.1)+(G*m*m/8)/(d*d*1.11*1.11)+...+... < G*m*m/(d*d) would be quite enough. The left side force is finite. Also always exceeds the right side force. No more is needed, no fancy math can change this strange fact.
| Feb26-07, 01:00 PM | #503 |
| Feb27-07, 05:26 AM | #504 |
Was it ... that a finite force is affecting every ball? All pointed to the left? At least at t=0?
| Feb27-07, 09:06 AM | #505 |
| Feb27-07, 11:42 AM | #506 |
I don't care for the mass center. I care only for the mass particles.
I am glad that you agree with me about those. > Could you give your proof that this force is also finite. I could, after this is settled with the majority here. That all balls are forced to the left hand side. |
| Feb27-07, 04:31 PM | #507 |
| Feb28-07, 03:19 AM | #508 |
> Well I'm settled on the finite force on every individual ball part.
Fine. Everybody else also? > Your paradox revolved around the fact that the center of mass of a closed system was supposedly moving. It can also revolves around the strange fact you admit. Only left pointed forces at t=0. A matter of choice. |
| Feb28-07, 07:27 PM | #509 |
This is absolutely ridiculous. OMP has provided a considerable amount of mathematic proof that this mathematic problem is unsolvable, results a divergency. Yet, Tomaz, you still continue to provide an equation that is set up, but not your process for solving it. OMP, thus far, has constructed the only VALID argument between the two of you. And you are still unable to provide full and complete calculation of the force on the center of mass, which is where the core of this seeminly fake paradox lies.
| Mar1-07, 06:19 AM | #510 |
What is your point?
That it is all OK, if all the net forces, to every ball, are finite and left pointing, as long as the force to the mass center is divergent? Is that your point? |
| Thread Closed |
| Thread Tools | |
Similar Threads for: A paradox inside Newtonian world
| Newtonian Gravitation Paradox ? | Classical Physics | 10 | ||
| Black Holes in a Newtonian (non-Einsteinian) World | General Astronomy | 2 | ||
| Field inside a cavity inside a conductor | Introductory Physics Homework | 3 | ||
| If ia charge is placed inside a conductor, is the electric field inside zero? | Introductory Physics Homework | 1 | ||
