Why does a rope have different stiffness than a rod of the same diameter?
The discussion centers around the differences in stiffness between a rope and a rod of the same diameter, specifically addressing bending, compressive, and axial tensile stiffness. Participants explore theoretical and conceptual aspects of material properties and structural behavior.
  • Some participants propose that a rope has lower bending and compressive stiffness compared to a rod of the same diameter, while having the same axial tensile stiffness.
  • One participant questions the definitions of compressive and bending stiffness, suggesting the need for clarification on what is meant by equivalent spring constant.
  • A participant explains that the stiffness of a prismatic rod is defined by the formula k = EA/L, where E is the modulus of elasticity, A is the cross-sectional area, and L is the length.
  • It is noted that the cross-sectional area of a rope is less than that of a rod due to the individual wires making up the rope, which affects its stiffness properties.
  • Another participant describes that a rope's modulus of elasticity is lower than that of the material it is made from, due to the properties of the wires within the rope.
  • One contribution emphasizes that a rope is weak in bending and compression due to its small second moment of area, while being strong in tension due to the distribution of forces among its fibers.
  • It is mentioned that a rod has a larger second moment of area, making it more resistant to buckling and resulting in higher bending and compressive stiffness compared to a rope.
Participants express differing views on the definitions and implications of stiffness in ropes versus rods, with no consensus reached on the overall comparison of their stiffness properties.
Limitations include the dependence on the definitions of stiffness and modulus of elasticity, as well as the assumptions regarding the material properties of the rope and rod.
crazie25
Why would a rope have a lower bending and compressive stiffness that a rod of the same diameter, but would have the same axial tensile stiffness?
what do you mean by compressive and bending stiffness?
Do you mean the equivalent spring constant?
Well a prismatic rod stifness is defined by [itex]k = \frac{EA}{L}[/itex].
Now let's suppose you have a rod and a rope with the same diameter and length. First notice that for the rope the cross sectional area A is equal to the cross sectional area of the individual wires, which will be less than the cross sectional are of our rod.
Now, the modulus of elasticity of our rope will be less than the modulus of elasticity of the material from which is made, due to the inherent property of the wires squeezing themselves.
Will our rope and rod of the same diameter and length have the same axial stiffness?
Theoretically, it'll depend solely on the rope effective modulus and the rod elasticity's modulus.
It's actually really simple, a rope is made up of very small fibers. Imagine taking one fiber of the rope, and pulling on it, then pushing on it or bending it. It's really weak in bending, due to it's small second moment of area [a factor of the area and the geometry], and in compression it buckles easily because of the same factor. In tension however it is pretty strong for its thickness. A bigger rope is made up of many such stands and as such will share their properties.
A rod, made up of a material with the same properties as the rope, will have a similar resistance to tension. However it is MUCH harder to buckle because it has a very large second moment of area, and so it will have a much higher bending and compressive stiffness.
I know this is late for OP but it was the second google result of one of my searches so this might still help someone.
  • · Replies 23 ·
10K
  • · Replies 16 ·
