| New Reply |
Average Rate of Heat Gain in Fridge |
Share Thread | Thread Tools |
| Nov13-06, 04:22 PM | #1 |
Just curious if anyone knows an approximate for the average rate of heat gain for a common fridge? Im going to do an experiment to calculate the average rate of heat gain in my fridge and want to know if my numbers in the ballpark
| Nov13-06, 11:44 PM | #2 |
An average household fairly efficient refrigerator will use about 50 kWh per month.
According to this cost guide: Energy Cost Guide That will maybe give you a starting point. |
| Apr22-11, 01:48 PM | #3 |
| Apr26-11, 01:32 PM | #4 |
All you need is the average power consumption of the refrigerator, the temperature of the refrigeration compartment, and ambient temp. If you approximate the refrigerator as a Carnot Vapor Refigeration Cycle, you can calculate the coefficient of performance using just the temps:
[tex]\beta_{max}=\frac{T_{c}}{T_{h}-T_{c}}[/tex] and using the coefficient of performance and the power input (with an efficiency for the the compressor, maybe 80%), the heat gain is calculated as: [tex]\dot{Q}_{in}=\beta_{max}*\frac{\dot{W}_{c}}{\eta}[/tex] So for a refrigerator holding at 35 degrees fahrenheit (275 K) and ambient of 75 degrees fahrenheit (297 K), with an average power consumption of 70 watts (50kWh per month), and assuming the power consumption is mainly from the compressor, the average heat gain would be about 1000 watts if I did the calcs right... |
| New Reply |
| Thread Tools | |
Similar Threads for: Average Rate of Heat Gain in Fridge
| average rate | Calculus & Beyond Homework | 4 | ||
| Average rate of energy transfer & rate of energy dissipation. | Introductory Physics Homework | 4 | ||
| Heat Gain in a Fridge Experiment | Introductory Physics Homework | 2 | ||
| can the water (100 oC) gain latent heat energy from the same temperature object? | General Physics | 2 | ||
| rate of heat transfer and heat conductors | General Physics | 3 | ||
